how much play should my timing belt have
Old Nov 4, 2005 | 06:03 AM
streetracerof06's Avatar
Default how much play should my timing belt have
ok so i just put a water pump on my b16. the engine is out of the car because i just ordered it and was going to do the water pump while it was out of the car since it would be easier. well my timing belt on the left side from the cam gear down to the crank gear has about 1 1/4 in play in it. that would be like 5/8 in each way. the tensioner is tight and every thing is right. should there be that much play in it or do i need a timing belt.
Old Nov 4, 2005 | 06:10 AM
LSEGHATCH's Avatar
Default Re: how much play should my timing belt have (streetracerof06)
There shouldn't be that much play at all, it should be pretty snug. I know you said the tensioner was tight but did you happen to remove it completely while doing the water pump replacement? If so you could've maybe put the spring in the wrong way on the tensioner or your tensioner could be shot.
You can get OEM tensioners at prostreetonline or your local honda dealer.
Old Nov 4, 2005 | 06:49 AM
IHateJDM's Avatar
Default Re: how much play should my timing belt have (LSEGHATCH)
you should have about 3/4" - 1" total play in it. After you reinstalled the belt, did you manually turn the motor 3-4 full rotations?
Ennis555
Apr 11, 2017 09:21 PM
dj-t
Feb 20, 2012 07:13 PM
5.56
Jun 17, 2009 05:19 PM
SuicideSlide
Oct 15, 2004 10:06 AM
JaiDieM
Sep 11, 2003 06:55 PM
