car wont go into gear!!!!!!
Old Nov 4, 2005 | 05:23 AM
VOLTRONRacing's Avatar
Default car wont go into gear!!!!!!
2nd gear grindin like a *****!!!!!!
after 5 minutes of driving....
the clutch pedal started getting pressure again...
goes into all gears smoothly.....
i went and bled the clutch lines...
no leak anywhere(in engine compartment)
BUT
if i engage the clutch pedal with my hands, i can see lil black liquid coming out of the hole in the firewall that the pedal goes into the clutch cylinder..
any ideas?
Old Nov 4, 2005 | 05:31 AM
snatch's Avatar
Default Re: car wont go into gear!!!!!! (VOLTRONRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VOLTRONRacing &raquo;</TD></TR><TR><TD CLASS="quote">
BUT
any ideas?</TD></TR></TABLE>
Clutch master cylinder is bad and leaking. The seals inside of there go bad after time and eventually wear out. Replace it.
Old Nov 4, 2005 | 05:47 AM
Default Re: car wont go into gear!!!!!! (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
Clutch master cylinder is bad and leaking. The seals inside of there go bad after time and eventually wear out. Replace it.</TD></TR></TABLE>
is that one of the reasons why my clutch reservoir was EMPTY? and pedal had no pressure last night??? pedal went down and stayed down.
then wont go into gear no more..
Old Nov 4, 2005 | 05:57 AM
boostedcivicsir's Avatar
Mr. Badwrench
then wont go into gear no more.. </TD></TR></TABLE>
yes, if there is no fluid to build pressure, your clutch will not disengage. pull back the boot on the slave as well to see if it is leaking also.
Old Nov 4, 2005 | 06:20 AM
Default Re: car wont go into gear!!!!!! (boostedcivicsir)
stoopied question...
but do i buy a clutch master cylinder for an LS or CX?
Juans_MX3
Nov 11, 2011 04:51 PM
Edul59
May 19, 2009 07:37 PM
markski037
Dec 21, 2005 05:13 PM
92BlackSi
Oct 26, 2004 03:51 PM
