stick too long
Old Nov 4, 2005 | 03:34 AM
Jxi8s2k's Avatar
Default stick too long
on the 6th gen accords manual, the stick is reallllly long. is there anyway to shorten the stick? i remember reading up on something on how to cut the shifter, but is there anyway to replace it? i have a short shift kit but the throws are still long due to the long shifter.
Old Nov 4, 2005 | 05:11 AM
notoriousB's Avatar
Default Re: stick too long (Jxi8s2k)
just cut it down with a dremel. I cut mine about 1" and it's much better. There's no true short shifter available for the 6th gen that I know of.
Old Nov 4, 2005 | 06:25 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: stick too long (notoriousB)
chop and weld
Jxi8s2k's Avatar
after you cut it...dont' you have to re-thread it?
Old Nov 4, 2005 | 07:07 AM
Heat's Avatar
Any chance of a picture? Just wondering if it the normal length or if it was extended at some point (I have a '99 Lx 5-speed).
As for shortening the rod, yes, you'd have to rethread it if you went that route. You could cut out a piece and re-weld it, but make sure that the weld is very solid. You don't want to be shifting one day and break the rod off at the weld.
Old Nov 4, 2005 | 08:41 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jxi8s2k &raquo;</TD></TR><TR><TD CLASS="quote">after you cut it...dont' you have to re-thread it?</TD></TR></TABLE>
only if you're using the stock shift ****. If you're using aftermarket there's no problem.
sorry I don't have any pics. surprising because I have pics of just about every other thing I've done to the car...
Old Nov 4, 2005 | 04:10 PM
KaineJuice's Avatar
Cut the stick and get a shift **** that you have to srew the pins in, instead of the regular shift ***** that you have to thread.
Old Nov 5, 2005 | 02:25 AM
Jxi8s2k's Avatar
Default Re: stick too long (KaineJuice)
thanks
kriptik
Oct 8, 2004 12:46 AM
kriptik
Oct 4, 2004 03:50 PM
ebayjackal1598
Jan 21, 2004 12:02 AM
integra dave
Aug 27, 2003 08:13 AM
almightyaccord
Feb 15, 2003 07:21 PM
