Bad Compression In One Cylinder
Old Nov 4, 2005 | 02:30 AM
Da1spaz247's Avatar
Default Bad Compression In One Cylinder
My compression test read as follows on my b18c1
175 210 200 200
Now I read somewhere on the internet that bad compression in only one cylinder usually can mean that an exhaust valve is bad or part of the valvetrain on that cylinder. I don't think it's a headgasket because I'm not leaking anything at all from my HG but I do burn alot of oil in HIGH RPM's in VTEC.
Just looking for some direction as to what I might do to figure out the exact problem and hoping i dont have to rebuild my block. The head... well... thats easy.
Thanks in advance
Old Nov 4, 2005 | 02:46 AM
untainted's Avatar
do a leakdown test on that motor yet?
Old Nov 4, 2005 | 08:50 AM
Da1spaz247's Avatar
Default Re: (untainted)
leakdown test, no. i just found out the comp results last night. wats needed for a leakdown test?
Old Nov 4, 2005 | 11:58 AM
untainted's Avatar
a leakdown tester ... something u can put a regulated like 100 psi into a cylinder when its tdc valves closed to see if a valve/valves leakin etc. and holds the pressure you may be able to buy one off of.
tunerschoice.com? well worth it if you know what your doing with it. you should do one of these leakdown tests it will easily show you the problem and be able to trouble shoot almost exactly what it is valve , hg, what have you .. when you do this test make sure your radiator cap is off if you see it bubble you know to change your hg. What was done with this motor how many miles is it completly stock ? tell me more about this. please
Old Nov 4, 2005 | 12:09 PM
Da1spaz247's Avatar
completely stock. supposedly rebuilt i have no idea how many miles ago. skunk 2 intake mani, r1 racing header (im thinking its a cheapo ebay brand)
i havn't changed the setup at all yet, just the vtec crossover with Chrome because it would LAG when vtec would crossover at 4500 rpm's.
i wish i knew how many miles were on the motor exactly but I'm thinking it's probably around 90k now. it's a 95' b18c1 and when i purchased it with my hatch back in July the seller (92Hatchy) said it had around 83k on it.
I'll check out the leakdown tester, thanks.
Old Nov 4, 2005 | 01:50 PM
nhsk84life's Avatar
dude mine was the same way a couple weeks ago. then i got the valves adjusted and everything was perfect on the compression test. i would go with a valve adjustment. if you dont know how to do it, a lot of ppl i know only charge 30 bucks.
Old Nov 4, 2005 | 03:13 PM
blkb18's Avatar
Default Re: Bad Compression In One Cylinder (Da1spaz247)
you most likely have excessive carbon on your exhaust valves from the burning oil, you could try decarboning them reletively cheaply.
Old Nov 4, 2005 | 05:27 PM
Da1spaz247's Avatar
Default Re: Bad Compression In One Cylinder (blkb18)
well i recently just used Seafoam on my car and I also recently just did a valve adjustment with my friend. It was very easy but took a little time. I might be able to get the adjustment professionally done over at the dealership because i know someone who works at a Wilde Honda... but we'll see. I'm definitely set on buying a leakdown test though, it seems like a great tool to have and Summit Racing has one on Amazon.com for only $70
Old Nov 4, 2005 | 07:57 PM
untainted's Avatar
if you stick with workin on cars a leakdown tester is like a must tells you alot .. and deals with troublshooting alot of problems
91EF919
18
Aug 4, 2009 12:50 PM
aznxpyroboi
Dec 9, 2007 10:09 PM
dreamreaperx
Dec 20, 2006 02:01 PM
evotux
Nov 20, 2006 07:01 PM
silverEH2
Oct 14, 2003 11:54 AM
