Sopping wet floor?
Old Nov 3, 2005 | 10:03 PM
Backk InTheDA's Avatar
I hate everything
Default Sopping wet floor?
No this isn't the notorious, leaky passenger seat floor under the dash, it's actually the back seat behind the passenger side.
What happened was, I was getting out of my car tonight, I reach behind my passenger seat to grab my club, and the floor is SOPPING wet, when i say sopping, I mean sopping.
The type, where you put your fingers to it, and it just ooze's up there's so much of it.
It was dark, so I just threw some towels over it. I can't imagine where this is coming from, has anyone ever had this problem, or if not, any suggestions?
And it is infact water, not gas or anything to that extent.
It's only behind the passenger seat, and it doesn't extend under the seat, just goes back to where the backseat starts to curve upward on the floor, and the whole square area of it was wet, and it was equally wet, which I don't understand, either or any suggestions would be dope.
Old Nov 3, 2005 | 10:10 PM
chahsiubow's Avatar
Happened to my car.. sunroof drain tube was disconnected on the passenger side. Check under your spare tire. Mine would be flooded pretty bad.
Old Nov 3, 2005 | 10:12 PM
I hate everything
Default Re: (chahsiubow)
My spare tire has been removed, and I just have an empty trunk. Is it behind the plastic covers to the back?
Old Nov 3, 2005 | 11:36 PM
xxxmikenicexxx's Avatar
Default Re: (BuilttB18C5)
I had the same problem, I believe it was from the hatch drains the run on either side behind the panels in the hatch...they were both disconnected...if you have a sunroof that could be it also.
Old Nov 4, 2005 | 12:03 AM
I hate everything
Default Re: (xxxmikenicexxx)
Is this hard to fix?
Old Nov 4, 2005 | 05:12 AM
chahsiubow's Avatar
nope... pop off the interior plastic pieces and take a look. you'll prolly figure it out by sight.
Old Nov 4, 2005 | 06:18 AM
kulrevon's Avatar
do you have a sunroof? if so take out the headliner and start by checking the tube there and following it back. also make sure your antenna is sealed nicely that can cause a leak and will get the back seat wet.
Old Nov 4, 2005 | 08:42 AM
I hate everything
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">do you have a sunroof? if so take out the headliner and start by checking the tube there and following it back. also make sure your antenna is sealed nicely that can cause a leak and will get the back seat wet.</TD></TR></TABLE>
Yeah, I have a sunroof, i believe my antenna is sealed, is it hard to remove a headliner??
Thanks for all the help guys!
Old Nov 4, 2005 | 03:59 PM
I hate everything
Bump for instructions on how to remove headliner
Old Nov 4, 2005 | 04:29 PM
Dogginator's Avatar
Daisy... Daisy...
Search google for "hondahookup manual". You'll find what you need.
Old Nov 4, 2005 | 06:07 PM
namsoofabolus's Avatar
Default Re: (Dogginator)
same happened to me...i thought it was the rain...but my side wasnt wet...so...then it went away....o well....im happy its gone
Old Nov 4, 2005 | 06:30 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (namsoofabolus)
happen to me to, but it was raining outside. i also have my trunk gutted with a sunroof and my spare tire in still. but my major problem is that my trunk will get water into it, if washed or in rain??
Old Nov 5, 2005 | 03:41 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">happen to me to, but it was raining outside. i also have my trunk gutted with a sunroof and my spare tire in still. but my major problem is that my trunk will get water into it, if washed or in rain??</TD></TR></TABLE>
Water leaks can be quite difficult to find. Stripping the interior in the affected area is the first step. If you can cause the leak with a hose, you are in luck, as some leaks only occur when driving due to the water spray. You need to strategically line your trunk with paper towels taped to the sides, trunk lip, etc., where the towels serve as a leak detector. It may be leaking quite a distance from where you normally see the water. If you are systematic with towel placement, you can isolate the entry point quite easily.
Old Nov 5, 2005 | 08:02 PM
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Water leaks can be quite difficult to find. Stripping the interior in the affected area is the first step. If you can cause the leak with a hose, you are in luck, as some leaks only occur when driving due to the water spray. You need to strategically line your trunk with paper towels taped to the sides, trunk lip, etc., where the towels serve as a leak detector. It may be leaking quite a distance from where you normally see the water. If you are systematic with towel placement, you can isolate the entry point quite easily.</TD></TR></TABLE>
Thanks
$i♡myblackem2$
Honda Civic (2001 - 2005)
Nov 24, 2014 10:27 PM
twiztid00002
Jan 22, 2008 07:15 PM
stevescivic
10
Feb 27, 2007 06:53 AM
electronspeeder
20
Apr 2, 2002 03:24 PM
