how high can i safely rev my Z6?
Old Nov 3, 2005 | 08:51 PM
Crimson_Tide's Avatar
Default how high can i safely rev my Z6?
hey guys i traded my p28 to my buddy for his p30... hes using the p28 for hondata and im using his p30 for the more aggressive fuel and ignition maps... anyways i know that the p30 doesnt cut revs until 8200 or 8300 but i know that i cant rev that high... my z6 head is stock with a little under 100k on it... i was just wondering what i should use as my redline... thanks a lot
-Josh
Old Nov 3, 2005 | 08:52 PM
Default Re: how high can i safely rev my Z6? (Crimson_Tide)
also just curious... does the p30 cut ignition or fuel? thanks
Old Nov 4, 2005 | 12:10 AM
91civicDXdude's Avatar
if you spin it to 8200 you'll more than likely spin a bearing. your head is stock, you're not making power nearly that high. i'd say stick to around 7500 rpm
Old Nov 4, 2005 | 05:52 AM
Default Re: (91civicDXdude)
i know that but im talking for like autox when it would be more benefitial to leave it in gear instead of shifting... what should i keep the revs under? i didnt know that you can spin a bearing from reving too high... i was just thinking valve float and bent valves as the result... hmmm anyone else?
-Josh
Old Nov 4, 2005 | 06:07 AM
EJ2-Fluffy's Avatar
Default Re: (Crimson_Tide)
dont rev that high unless you want a bomb to happen to your stock motor.
Old Nov 4, 2005 | 06:15 AM
CRXBart's Avatar
I shift mine at 7200. it pulls real nice @ about 6800-7000. I wouldn't rev it higher than 7500.
Old Nov 4, 2005 | 06:36 AM
CO_RaceFab's Avatar
I have reved two different z6 motors to 10,000 one motor had 180,000 the other one I dont know how many miles were on it but It didn't make any power up there. it should be fine if you over rev it on accident, but no power over 7000
I had an allmotor chip in a pr4 10,000 rev timing added on top and a little more fuel
p.s. both motors still run to this day in different cars and I revved them liikke that over 2 years ago
Old Nov 4, 2005 | 06:45 AM
Timmah!!'s Avatar
Install a nice came with proper valve train and run it to 7800 rpms.
Old Nov 4, 2005 | 08:32 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: how high can i safely rev my Z6? (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I shift mine at 7200. it pulls real nice @ about 6800-7000. I wouldn't rev it higher than 7500.</TD></TR></TABLE> bout as high as you can do on stock D
JR CIVIC
Sep 27, 2011 09:58 AM
ten2doyle102
13
Aug 8, 2008 07:48 PM
Liquidgsr
Jun 1, 2005 06:15 AM
SohcVtecCrix
Nov 19, 2002 01:12 PM
DJCRX
Apr 26, 2002 11:53 AM
