retro fit 96 accord?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White V6 »</TD></TR><TR><TD CLASS="quote">why would you want to put that on your car </TD></TR></TABLE>
Because HID 'kits' are garbage and projector retrofits give off awesome light output, great cutoff, and cool colors, and theyre like a jillion times better than stock lights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">Because HID 'kits' are garbage and projector retrofits give off awesome light output, great cutoff, and cool colors, and theyre like a jillion times better than stock lights.</TD></TR></TABLE>
so what exactly do you want to do? you want to retrofit your headlights or do you want to put projectors. like these by the way, the output on these things suck trust me. they give your car a cool look at night but for vision their out put is really bad.
http://cgi.ebay.com/ebaymotors...QrdZ1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 »</TD></TR><TR><TD CLASS="quote">are you talking about projector retrofit??? (i.e. BMW projectors into 96 Accord)</TD></TR></TABLE>
yeh wat he said. sorry yeh retrofit projectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ptown17 »</TD></TR><TR><TD CLASS="quote">..the output on these things suck trust me. they give your car a cool look at night but for vision their out put is really bad.</TD></TR></TABLE>
OK, can't you put the projector assembly from the BMW into the housing of the above lights to use the better quality projectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">
OK, can't you put the projector assembly from the BMW into the housing of the above lights to use the better quality projectors?</TD></TR></TABLE>
You could, but it would be more difficult. With a standard reflective housing, you can just make a hole, bolt the projector in, and use the housing adjustment screws to adjust the beam pattern. With those, you have a lot less room to work with and you have to adjust it using a bracket instead of the stock mount points.
does anyone have any pics of they're DIY retrofit job? pics of the back of the housing and how the projectors fit and where cuts where made would be nice..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dj14aZnS »</TD></TR><TR><TD CLASS="quote">does anyone have any pics of they're DIY retrofit job? pics of the back of the housing and how the projectors fit and where cuts where made would be nice..</TD></TR></TABLE>
Bionic has a really good setup, and right now i'm doing an S2000 retrofit into some Civic headlights. NOt accords, but I should be able to give advice if you want
check the forums at http://www.hidplanet.com
here's my unfinished retrofit without shrouds
Modified by zidek at 3:46 PM 11/5/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zidek »</TD></TR><TR><TD CLASS="quote">check the forums at http://www.hidplanet.com
Modified by zidek at 3:46 PM 11/5/2005</TD></TR></TABLE>
THATS HOW I WANT MINE TO LOOK LIKE!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianalbutt »</TD></TR><TR><TD CLASS="quote">
THATS HOW I WANT MINE TO LOOK LIKE!!!!!</TD></TR></TABLE>
I hope not, cause that definitely needs shrouds and bezels...and what K are you using, cause that looks kinda green....
I hope not, cause that definitely needs shrouds and bezels...and what K are you using, cause that looks kinda green....</TD></TR></TABLE>
well i mean u get the picture when his is done
Thanks bro.
Unfortunately...I got into a car accident and smashed the headlgihts.
Anyhow, I'm in the process of something crazier than before....
I'm definatley doing the projector turning signals and moddified 05+ S2000 low beams, but I can't decide between modded S2000 projectors or modded TSX highbeams.
I'll let you guys know when it's done...
</TD></TR></TABLE>Thanks bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">Unfortunately...I got into a car accident and smashed the headlgihts.</TD></TR></TABLE>
sucks
sucks
