Programming 99-00 keyless entry?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 »</TD></TR><TR><TD CLASS="quote">take it to a dealership. they need to use their HDS unit to intalize (sp?) the keys with a code</TD></TR></TABLE>
He's talking about the remotes which can be done by hand I believe, I think your thinking for the immobilizer on the 01-up T5 transponder keys which need to be used with the Honda handheld.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
He's talking about the remotes which can be done by hand I believe, I think your thinking for the immobilizer on the 01-up T5 transponder keys which need to be used with the Honda handheld.</TD></TR></TABLE>
you might be right, the question was kinda open ended
Key off, key on, press any button on remote, key off, key on, press remote, key off, key on, press remote.
The power lock system should cycle at this time, meaning it is ready for programming. Then press any button on any and all remotes you have to program. Remove the key and you're done. It's actually easier to do than it is to type.
More detailed here:
https://honda-tech.com/zerothread?id=1363051
More detailed here:
Thanks but it just isn't working for me I tryed the remote on my 2 door ex 99 and my 96 four door (used the 96-98 programming details for the four door) maybe the remote isn't working because its off a '04 SI??? I don't know whats going on....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivichatch »</TD></TR><TR><TD CLASS="quote"> maybe the remote isn't working because its off a '04 SI??? I don't know whats going on....</TD></TR></TABLE>
That would be it, that remote will not work.
