88 accord. when clutch depressed, wants to die...
Old Nov 3, 2005 | 05:22 PM
iderek's Avatar
Default 88 accord. when clutch depressed, wants to die...
i have a 1988 accord and when i am moving along the road at normal speeds and then have to stop, at a street light for example, i shift down from like fourth gear to third and then third gear to second, and then depress the clutch and brake to a stop, then the motor starts to idle very very low like its going to die, and sometimes it does. what is the problem??? please help...
Old Nov 3, 2005 | 05:34 PM
deserthonda's Avatar
Default Re: 88 accord. when clutch depressed, wants to die... (iderek)
u could have a vacc leak, u could have carb problems,, first make sure the pcv valve is ok,, if it is leaking will give u a very low idle,,,,,,,pcv valve is located behind valve cover below the air cleaner bracket, ,, let car idle, get some pliers, squeeze the pcv valve hose ,,if idle smooths u found the source........if that does not help,, try blowing out the idle circuit,, remove air cleaner on back of carb there is the idle solenoid, first off turn key on and off make sure u hear it click ,, if it clicks remove the 8 mm nut, careful do not loose the solenoid 0-ring, spray some carb cleaner in the hole, u need some compressed air, blow airin the hole as well do it 2 times, put together and see if idle smoothes up.. ..Try those and post results
Old Nov 4, 2005 | 08:53 AM
notoriousB's Avatar
get that clutch some prozac soon! It may try to commit suicide!
seriously tho: does it also idle low when it's in neutral without the clutch depressed, or is it only when the clutch is in? if only when the clutch is in, the clutch could be dragging a little, putting some slight load on the motor causing the low idle. if that's the case adjusting the clutch should resolve the problem.
Old Nov 4, 2005 | 10:24 AM
Default Re: 88 accord. when clutch depressed, wants to die... (notoriousB)
clutch adjustment won't solve this problem,,,,,,,,,if it is too tight ( no free play ) it will slip. if too loose ( too much free play ) it wil have a hard time engaging gears..... but he said nothing about that..
Old Nov 4, 2005 | 10:25 AM
what happens when car is just idling in neutral?? does it idle ok ??
Old Nov 4, 2005 | 11:21 AM
notoriousB's Avatar
Default Re: 88 accord. when clutch depressed, wants to die... (deserthonda)
isn't that the question I asked?
Old Nov 4, 2005 | 12:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">isn't that the question I asked? </TD></TR></TABLE>
OOOps sorry buddy did not mean to step on ur toes ,, yes it is the same thing u asked ,,,,,ehy what can i say great minds think alike
Old Nov 4, 2005 | 02:08 PM
iderek's Avatar
yeah, even when it's in neutral, it still idles lower and lower until it wants to die. any ideas....?? thanks
Old Nov 4, 2005 | 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iderek &raquo;</TD></TR><TR><TD CLASS="quote">yeah, even when it's in neutral, it still idles lower and lower until it wants to die. any ideas....?? thanks</TD></TR></TABLE>
if u scroll up a bit i gave u some suggestions,, do those and see if it helps..
InvaderTrax
Jan 4, 2006 07:33 PM
iderek
Nov 18, 2005 02:15 PM
1990AccordEX
Oct 1, 2005 06:23 AM
SlackerAccord
Sep 22, 2005 08:49 PM
syshackmin
Jul 5, 2005 11:57 AM
