1984 Interceptor vf1000 Motorcycle Fuel Relay Problem ?
Old Nov 3, 2005 | 03:42 PM
ReiGnMaN's Avatar
Default 1984 Interceptor vf1000 Motorcycle Fuel Relay Problem ?
Okay..... I have been playing with this for a while.... and the " Honda Motorcycle Manuals " tell you NOTHING about the voltage in koeo , cranking etc... I need to know what the voltage needs to be for this fuel pump to run.... this is the only thing standing in my way of reviving this beautiful machine.... I don't know if a relay is bad..... wiring from it , no clue . It dosent prime the fuel pump when the key is turned to on , nor send voltage when cranking.... it has 0.040-0.240v at the green ( ground ) wire at the pump connector , and has roughly 6.5-7 volts at the black/blue pump positive wire..... PLEASE help me if you are familiar with this system......
civic28
Mar 26, 2014 04:18 PM
KansasKev
10
Jun 1, 2007 12:36 PM
drintegra
Jun 14, 2006 05:27 PM
Jamison
Jul 11, 2002 12:07 PM
