Will 4WS work with p28?
Old Nov 3, 2005 | 12:29 PM
snowblind7x's Avatar
Default Will 4WS work with p28?
I know there's a seperate ecu for the 4ws but is it in any way connected to the p13/p14 to make it work? I'm gonna run a p28 with my h22 swap and wanna know if 4WS will still work. Thanks in advance.
Old Nov 3, 2005 | 12:31 PM
tdo's Avatar
tdo
Default Re: Will 4WS work with p28? (snowblind7x)
no.
edit - well i never seen it done, so i doubt it. P28's have nothing to do with 4ws.
Old Nov 3, 2005 | 12:43 PM
AndyD's Avatar
The 4ws is COMPLETELY separate from the ECU. The ONLY info the 4WS system gets from the ECU is the speed of the car. You can use any ECU.
So, yes, it will work.
Old Nov 3, 2005 | 12:48 PM
tdo's Avatar
tdo
Default Re: Will 4WS work with p28? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">The 4ws is COMPLETELY separate from the ECU. The ONLY info the 4WS system gets from the ECU is the speed of the car. You can use any ECU.
So, yes, it will work.</TD></TR></TABLE>
well there you go. it can be done.
i didnt even know 4ws wasnt part of the ecu.
Old Nov 3, 2005 | 03:23 PM
vinuneuro's Avatar
What is the difference between the normal p13s and the 4ws p13s?
Old Nov 3, 2005 | 05:25 PM
raser5050's Avatar
Default Re: Will 4WS work with p28? (tdo)
I use p28 ECU and my 4WS work fine
2camsaam
13
Oct 2, 2015 12:44 PM
s032105k
Engine Management and Tuning
Mar 2, 2011 02:23 PM
EGricky
Jul 10, 2009 06:16 AM
em1_fox
Oct 13, 2007 10:49 AM
B16aSir2
Jan 22, 2006 06:28 PM
