are all LS intake manifolds and injectorsthe same?
is the 94-01 ls intake manifold the same? aside from obd1 and obd2? i plan to use an obd2 ls intake manifold (its in better condition
) with obd1 wiring.
) with obd1 wiring.
I think OBD1 and OBD2 have different injectors due to the plugs. You can confirm this here by the part number.
http://www.acuraparts247.com
yea the injectors are different.
but i just want to use the bare intake manifold (obd2) and swap all the engine wiring and injectors from the obd1 IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by go2sleep »</TD></TR><TR><TD CLASS="quote">yea the injectors are different.
but i just want to use the bare intake manifold (obd2) and swap all the engine wiring and injectors from the obd1 IM.</TD></TR></TABLE>
your should be fine if you use the obd1 component's.
