leaking coolant at oil pan gasket or bolt
Old Nov 3, 2005 | 10:41 AM
eth0r's Avatar
Default leaking coolant at oil pan gasket or bolt
i drive a 90 civic with a b16a1, after replacing the thermostat i noticed leaking coolant driping from the oilpan seam or out a bolt on the corner of the block in front of the crank pulley side, the bolt is so close to the pans gasket i cant tell where its coming form anyone know what casues this its only when the car is running? loose bolt? new gasket?
NOT my picture, but we share the same problem.. mine isnt as bad but from 2 different spots..small drips
Modified by eth0r at 2:25 PM 11/3/2005
Old Nov 3, 2005 | 01:47 PM
non-VTEC's Avatar
Default Re: leaking coolant at oil pan gasket or bolt (eth0r)
your water pump is leaking and the coolant is just running along the oil pan and gasket area......look very carefully behind the crank pulley and you will probably see green coming out of the little hole on the bottom of the timing belt cover.
Old Nov 3, 2005 | 03:36 PM
Lord Helmet's Avatar
Default Re: leaking coolant at oil pan gasket or bolt (non-VTEC)
Also according to honda it's ok for the area under the water pump to drip a "little" because it's normal, there's a little bleed screw on the righthand side of the water pump which causes a little bit of coolant to drip from that area and on to the oil pan. If that's not the case the water pump gasket is probably going bad. When was the last time you replaced the water pump?
Old Nov 3, 2005 | 05:02 PM
eth0r's Avatar
Default Re: leaking coolant at oil pan gasket or bolt (Lord Helmet)
i put the motor in about 2 months ago , the guy that own it before said he changed it 10k before i got it.. but i did change the thermostat and refilled the rad to the max, i havent drove the car yet just noticed while fixing and idle problem ive had, ill have to get it checked out soon
tony_yang
Aug 10, 2024 06:05 PM
cstap
Oct 10, 2013 06:34 AM
m3dia_lab
Aug 22, 2004 04:21 PM
ithrowpoop
Jun 12, 2003 03:19 AM
tylermaxon
Feb 13, 2003 04:00 AM
