power steering leak
Old Nov 3, 2005 | 09:01 AM
dudefella's Avatar
Default power steering leak
So I'm leaking a little power steering fluid... it's not much of a problem, I just have to top it up every 3-4 weeks or so. Anyhow, my previous car was a grand prix, and when it started leaking PS fluid (a whole hell of a lot more than my teg does), I started putting in this PS fluid that's supposed to fix leaks.
That stuff worked wonders... does anyone put out anything similar for Hondas?
Old Nov 3, 2005 | 09:04 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: power steering leak (dudefella)
I'm sure you can use the same stuff. But first, have you determined where the leak is coming from? Perhaps it's an easy fix. Try repairing it the correct way before doing it the "ghetto" way.
Old Nov 3, 2005 | 09:15 AM
dudefella's Avatar
Default Re: power steering leak (shamoo)
I've tried to spot it... the leak is so small that I can't find it. There's never any fluid visible, and I don't even notice it on the driveway. The gangsta fix works for me
Old Nov 4, 2005 | 10:13 AM
SIK IN DA HED's Avatar
New User
i dont recommend that bandaid leak fix. find out whats goin on and fix it. its probably the hose or a bad seal.
Old Nov 4, 2005 | 10:21 AM
OPI-GSR's Avatar
Yeah mine started leaking like that....I removed the pump and looped my system
AcuraTilIDie
Mar 18, 2008 08:20 PM
94c1v1cex
May 21, 2007 05:03 PM
knightnam
Aug 16, 2006 10:44 AM
peel17
Jan 20, 2005 09:14 AM
nek0
Sep 25, 2003 08:06 AM
