Which fuel pump???
Old Mar 8, 2002 | 06:19 PM
VTECVillain's Avatar
Default Which fuel pump???
I have a 92 VX with a 99 B18C1 and I've still got the stock VX fuel pump. I would like to upgrade this to an aftermarket one, or even better, an OEM pump from another Civic/Integra. Which pumps will fit my car without any modifications? I've read somewhere that the GS-R pump will work, what about the Integra Type-R, 99-00 Si or any others? If anyone knows, let me know which ones work and the years that are compatible.
Old Mar 8, 2002 | 07:39 PM
SIINSI's Avatar
Default Re: Which fuel pump??? (VTECVillain)
I'm not sure but, IF the GSR works, then so does the Type R and Si.
If I had to guess, I think they all work. I have a Type R pump in my 00 Civic.
Miguel
Old Mar 8, 2002 | 08:12 PM
stkd16z6's Avatar
for the most part a fuel pump is a fuel pump, the only difference is usually flow. i've got a S2000 pump in my civic, and i've seen supraTT and Rx-7 pumps in civics also.
Old Mar 9, 2002 | 01:01 PM
karmannghia's Avatar
Try summit racing. BBK 250 lph for only 130 bucks. Its much bigger than your stock. Its a completely stock bolt in. Its a walbro rebadge, same as Holley. I just installed mine 1 wk ago.
Old Mar 9, 2002 | 02:54 PM
KekeK_5G's Avatar
Jim at Motorvations (205)-661-3600 sells the walbros for about $105
any model you want, direct bolt in. He usually has them in stock too.
joni_titi
Honda S2000
12
Jan 25, 2010 03:38 PM
wernhersey
Oct 6, 2008 03:44 PM
GeniusTech
Feb 13, 2008 05:26 PM
24psi
Apr 15, 2004 10:25 AM
-Darren-
13
Mar 15, 2002 11:44 AM
