integra to civic suspension swap
i have a 1993 civic hatch and want to swap susp i have a lot of parts "in stock" i have comp 1992 integra ls susp as for rear going from drum to disc do i have to change master cyl or anything else for the brakes ? my car was stolen and recovered i have a 99 gsr they took the motor out but never got it so im lucky for that. but while its apart i want to do something different if the 1992 susp does not bolt up would 94 gsr or ls susp work SOMEONE PLEASE HELP THANKS.
Modified by fast hatch at 9:38 AM 11/10/2005
if you want to change the civic drum to integra rear disc brake.. you have to take out and exchange the whole rear assembly and e-brake line.. that is all you have to change b/c i did that conversion with my 96 civic..
The 92 Integra suspension should fit your 93 Civic just fine. I know the rear LCAs are different, so you may or may not be able to use them.
As said before, you will just need to swap the rear trailing arms, rear brake hoses & rear e-brake cables to get a rear disc swap done. It is also recomended that you swap in the proportioning valve from the 92 Integra, as long as the Integra didn't have ABS. If you don't have this part you should be okay, but I recomend you find one & eventually swap it in...
You can also use the prorportioning valve from any "NON ABS Rear Disc" 88-95 Civic/CRX/Del Sol or 90-97 "NON ABS" Integra...
what1118
Jan 17, 2009 01:55 PM
unknown0001
14
Aug 11, 2005 05:31 AM
unknown0001
14
Aug 30, 2004 09:00 PM
