please help!! my car isn't starting!!
Old Mar 8, 2002 | 06:10 PM
accordfreak's Avatar
Default please help!! my car isn't starting!!
ok i have a 94 accord ex with I/H/E, crane cam ignition w/ ps92 coil, magnacore wires, and the v-force.
in the past the v-force messed up my ecu so i had to reset it in order for my car to work. also before my coil had a loose wire so my car didn't start... all those past time my car cranks but no start.
this time i tried everything..reset the ecu...i threw out the v-force.. and checked all the wires to the ignition...what makes a car start?? does anybody know what the problem is?? first time i started the car today then a second later it just died and never started again...it feels like it wants to start but seems like not enough spark or something to fire it up!.. please help thanks.
Old Mar 8, 2002 | 06:28 PM
TheShad0w's Avatar
Default Re: please help!! my car isn't starting!! (accordfreak)
its something on your ignition....
[Modified by TheShad0w, 3:28 AM 3/9/2002]
Old Mar 8, 2002 | 06:46 PM
non-VTEC's Avatar
check your ignitor.......that's what it sounds like
Old Mar 8, 2002 | 10:01 PM
Veil_Side_'s Avatar
Default Re: please help!! my car isn't starting!! (non-VTEC)
Check your fuses, you said you had to reset the ECU, try checking around the fusebox, just my 2 cents
Old Mar 9, 2002 | 05:24 AM
brwnrice's Avatar
Default Re: please help!! my car isn't starting!! (Veil_Side_)
turn the ignition key with out actually starting the engine and hear for some humming sound in the back. if there isnt then you may have a faulty fuel pump. there are many factors to consider why your car is not starting and this is one of them.
Old Mar 9, 2002 | 10:55 PM
Default Re: please help!! my car isn't starting!! (brwnrice)
brwnrice!! whoa! i didn't hear any humming sound... i think i remember i usually hear the humming sound when i turn the key twice! would a fuel pump just quit like that?? thanks!
hcivic99
Jun 5, 2005 03:26 PM
squarehead
Feb 18, 2005 05:47 AM
viet_boi_racin
Jun 28, 2004 05:17 PM
accordfreak
Mar 12, 2002 12:56 PM
accordfreak
Nov 23, 2001 09:28 AM
