Changing an alternator belt on a 93 civic cx?
Old Nov 2, 2005 | 10:33 PM
mp5o's Avatar
Default Changing an alternator belt on a 93 civic cx?
Any precautions I should know about? Advice? It should basicly be, loosen *pulley* bolt... Slide alternator towards front of car, take off old belt, put on new belts, slide alternator back, tighten belt... Is that correct?
Old Nov 2, 2005 | 10:40 PM
SOHC4life 96's Avatar
Default Re: Changing an alternator belt on a 93 civic cx? (mp5o)
Yup, that's the jist of it. If you get any squeaking the belt is too tight, loosen it a little and your good to go.
Old Nov 2, 2005 | 10:45 PM
mp5o's Avatar
Default Re: Changing an alternator belt on a 93 civic cx? (SOHC4life 96)
^thanks!
Old Nov 2, 2005 | 10:51 PM
JDMlyfestyle's Avatar
the belt will also squek if it is too loose as well.
so you gotta kinda the sweet spot
Old Nov 2, 2005 | 10:55 PM
mp5o's Avatar
Default Re: (JDMlyfestyle)
^Thanks for the advice so far!
southernSCHEME
22
Jun 28, 2011 06:26 PM
failed
Sep 4, 2005 05:59 AM
519[H]Si
May 25, 2004 09:25 PM
Kato7997
Feb 23, 2003 11:23 AM
keithv
Aug 7, 2002 04:40 AM
