still having wheel hop after traction bars =(
Old Nov 2, 2005 | 09:55 PM
itsJDMyo's Avatar
Default still having wheel hop after traction bars =(
i have an LS motor in my 95' civic coupe. my car didn't wheel hop at all after the swap, but it started doing it after 2 weeks after the swap. i have ES motor mount inserts, nrg engine damper, and l-con traction bars. i don't wheel hop as much, but i still wheel hop to the extent where it could possibly damage something. i was told that it could could be my axles? suggestions please!
Old Nov 2, 2005 | 09:59 PM
sohc_turd's Avatar
Default Re: still having wheel hop after traction bars =( (itsJDMyo)
you have them pre loaded and all that goody?
Old Nov 2, 2005 | 10:04 PM
itsJDMyo's Avatar
Default Re: still having wheel hop after traction bars =( (unbanned_evosol)
what is preload again?
Old Nov 3, 2005 | 07:53 AM
itsJDMyo's Avatar
Old Nov 3, 2005 | 08:02 AM
Soccerking3000's Avatar
the traction bars need to be tight aka having a load on them, otherwise they wont do jack ****
Old Nov 3, 2005 | 08:10 AM
itsJDMyo's Avatar
Default Re: still having wheel hop after traction bars =( (Soccerking3000)
ok, it is preloaded then. just didn't know what it meant. what else could it be theN?
Old Nov 3, 2005 | 08:13 AM
might want to try and get new suspension bushings, but those are a pain in the ***, i havent heard anyone with wheel hop issues after traction bars are installed, sry i couldnt help more
Old Nov 3, 2005 | 09:22 AM
mike1114's Avatar
like just said, look into your ball joints and your bushings. They probably need replaced.
A new set of ES bushing for the entire suspension is only like $120, its just some time involved to put them all in. A few are a bitch to get out but can be donw.
Ball joints are pretty cheap too. But most likely its the bushings.
Old Nov 3, 2005 | 04:40 PM
itsJDMyo's Avatar
Default Re: still having wheel hop after traction bars =( (mike1114)
aite, i'll look into that
Old Nov 3, 2005 | 04:45 PM
Luserkid's Avatar
Hows your tires? Bald, or crappy tires will give you wheel hop.
Old Nov 3, 2005 | 04:52 PM
bokals's Avatar
Default Re: still having wheel hop after traction bars =( (Luserkid)
preloading .. meaning clutch, do you just drop it or preload the clutch?
Old Nov 4, 2005 | 12:27 AM
peacexisxfree's Avatar
Default Re: still having wheel hop after traction bars =( (core3200tm)
how are your motor mounts? solid? how are your axles? this can also cause wheel hop.
Old Nov 4, 2005 | 05:43 AM
fraknstien's Avatar
Default Re: still having wheel hop after traction bars =( (peacexisxfree)
yeah i think it might be the tires too.. but not too sure
Old Nov 4, 2005 | 05:44 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: still having wheel hop after traction bars =( (fraknstien)
How's your alignment?
Old Nov 4, 2005 | 06:45 AM
itsJDMyo's Avatar
Default Re: still having wheel hop after traction bars =( (litterbox)
my tires are good. they are khumo 711s. still a good amount of tread left. my alignment is also good. had it done a few months ago. my motor mounts are still very good (engine does not move at all when i rev). and i tried preloading the clutch, but when i shift from 1st-2nd, it still wheelhops. i'm just hoping it's my axle, i'll try getting that replaced next week
Old Nov 4, 2005 | 07:54 AM
accordm3's Avatar
make sure ALL your bolts are tight... sometimes something loose in your suspension could cause that
Old Nov 4, 2005 | 08:00 AM
b204dr's Avatar
khumo suck imo ! but i think try dropping tires pressure might help a little - and the suspensions bushings as every one is saying will help
Old Nov 4, 2005 | 08:02 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">my tires are good. they are khumo 711s. still a good amount of tread left. my alignment is also good. had it done a few months ago. my motor mounts are still very good (engine does not move at all when i rev). and i tried preloading the clutch, but when i shift from 1st-2nd, it still wheelhops. i'm just hoping it's my axle, i'll try getting that replaced next week</TD></TR></TABLE>
Your magic LS doesn't make as much HP or torque as my I/H/E/MSD GSR motor and I can both launch and shift at redline from 1 to 2 without it hopping the wheels. Oh, by the way: I don't have motor mount inserts, an "engine damper" or traction bars...and I do it on mismatched Winter tires .
Don't drop the clutch. Period. If you feather the clutch at the launch and on the 1-2 shift, you won't wheel hop. You'll get better E.T.s and you won't destroy your suspension and/or driveline components. It's not your suspension or damper setup: it's your driving. End of story
Old Nov 4, 2005 | 08:10 AM
b204dr's Avatar
Default Re: still having wheel hop after traction bars =( (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Don't drop the clutch. Period. If you feather the clutch at the launch and on the 1-2 shift, you won't wheel hop. You'll get better E.T.s and you won't destroy your suspension and/or driveline components. It's not your suspension or damper setup: it's your driving. End of story </TD></TR></TABLE>
You will def. figure this out after owning an awd lol
SilverPanda
Suspension & Brakes
Sep 4, 2007 01:37 PM
The Weather Man
Jan 22, 2006 10:07 PM
ghostsi69
Suspension & Brakes
13
Dec 3, 2005 12:58 PM
turbospool
Jun 10, 2003 04:30 PM
KoRE
Oct 17, 2002 08:24 AM
