p28 in a prelude??
Old Nov 2, 2005 | 08:33 PM
sloweredcivic's Avatar
Default p28 in a prelude??
i have done some searching but really didn't come up with anything. what chip would i need or can you run a p28 in a prelude? that main reason i am interested is i would maily like the speed limiter removed. does anyone know the factory setting in a p13?
Old Nov 2, 2005 | 08:42 PM
high_revs's Avatar
just buy a p28 and get it tuned....you'll be fine....
Old Nov 2, 2005 | 09:58 PM
EGmikeH22's Avatar
* B A N N E D *
your IAB secondaries won't open, you'll loose about 7hp around 3500 RPM.
there are base H22 maps for P28s, i'll see if I have one
Old Nov 2, 2005 | 10:31 PM
civicyellow's Avatar
or you can get it tuned for hondata, but you will still lose your secondaries
Old Nov 2, 2005 | 11:45 PM
mgags7's Avatar
you can get an s200 to control IABs on a p28, just use an extra wire like ac or something...
Old Nov 3, 2005 | 02:58 AM
Turbogixxer's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">you can get an s200 to control IABs on a p28, just use an extra wire like ac or something...</TD></TR></TABLE>
Or just add it to the board
http://www.pgmfi.org/twiki/bin...ToP28
Old Nov 3, 2005 | 10:28 AM
high_revs's Avatar
or take out the iab's.....which probably wont serve you no purpsoe...
Old Nov 3, 2005 | 10:59 AM
teamitr's Avatar
Default Re: (SB tuning)
what is a iab?
Old Nov 3, 2005 | 12:25 PM
EK9-Stealth's Avatar
Default Re: (teamitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamitr &raquo;</TD></TR><TR><TD CLASS="quote">what is a iab?</TD></TR></TABLE>
its the secondaries for the intake manifold. Buttterflies some my call it.
i heard p72 i think, the gsr ecu will control secondaries...
Old Nov 3, 2005 | 12:27 PM
tdo's Avatar
tdo
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.pgmfi.org/twiki/bin...ToP28</TD></TR></TABLE>
its pretty simple if you know how to solder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9-Stealth &raquo;</TD></TR><TR><TD CLASS="quote">
i heard p72 i think, the gsr ecu will control secondaries...</TD></TR></TABLE>
yea the P72 will have it.
Old Nov 3, 2005 | 01:36 PM
manman's Avatar
Default Re: p28 in a prelude?? (sloweredcivic)
Speed limiter is this in a newer model prelude? j/c cause my speed limiter is the red line in 5th gear hehe. on my 4th gen
manman's Avatar
Default Re: p28 in a prelude?? (manman)
not that i would know or anything.
Old Nov 3, 2005 | 01:44 PM
A Blue Lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manman &raquo;</TD></TR><TR><TD CLASS="quote">Speed limiter is this in a newer model prelude? j/c cause my speed limiter is the red line in 5th gear hehe. on my 4th gen</TD></TR></TABLE>
All JDM ecus are limited to 180km/h.
Old Nov 3, 2005 | 02:23 PM
tdo's Avatar
tdo
Default Re: p28 in a prelude?? (Featherfire)
I just added iab's to my P28 just right now. took me 3 mins.
its that easy.
Old Nov 4, 2005 | 08:07 AM
Default Re: p28 in a prelude?? (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">I just added iab's to my P28 just right now. took me 3 mins.
its that easy.</TD></TR></TABLE>
thats p28 with hondata s200? so its just a jumper? thats cake.. but how do you set when it opens?
Old Nov 4, 2005 | 08:29 AM
The Weather Man's Avatar
You want to remove your speed limiter?.....I'm assuming its a 4th gen. I thought the USDM models didn't have a speed limiter. So, If you have a JDM p13, just get a USDM p13, that way you keep your IABs.
Old Nov 4, 2005 | 10:31 AM
i was aauming it had a speed limiter do the jdm p13's have them if not then i don't need to change anything thanks for all the advice. its an obd1 jdm p13 going into a 99 sh i know it will be converted to obd1
Old Nov 4, 2005 | 12:43 PM
tdo's Avatar
tdo
Default Re: p28 in a prelude?? (EK9-Stealth)
thats p28 with hondata s200? so its just a jumper? thats cake.. but how do you set when it opens?</TD></TR></TABLE>
naw, thats a P28 with uberdata. i chipped the ecu then did the iab's.
its just a jumper if you have a auto ECU, but if you have a manual ecu you have to solder in a couple more things.
what do you mean "set when it opens" ??
Old Nov 4, 2005 | 12:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean "set when it opens" ??</TD></TR></TABLE>
I think he is talking about when the IABs open, like controlling it via of uberdata/crome/hondata/etc
Old Nov 4, 2005 | 04:53 PM
does anyone know if a jdm p13 has a speed limiter??
Old Nov 4, 2005 | 05:26 PM
Default Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if a jdm p13 has a speed limiter??</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Featherfire &raquo;</TD></TR><TR><TD CLASS="quote">
All JDM ecus are limited to 180km/h.</TD></TR></TABLE>
Old Nov 4, 2005 | 05:30 PM
tdo's Avatar
tdo
Default Re: p28 in a prelude?? (Turbogixxer)
I think he is talking about when the IABs open, like controlling it via of uberdata/crome/hondata/etc</TD></TR></TABLE>
oh ok.
yea you can set when it opens and when it closes with uberdata, chrome, hondata, etc.
Old Nov 4, 2005 | 06:56 PM
dfoxengr's Avatar
they are controlled by vacuum. the sensor there just tells the computer when they are open.
Old Nov 4, 2005 | 08:54 PM
how hard is it to remove the speed limiter form a jdm p13 then or is it easier to just use a usdm p13?
Old Nov 4, 2005 | 10:08 PM
matix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to remove the speed limiter form a jdm p13 then or is it easier to just use a usdm p13?</TD></TR></TABLE>
Easy go buy a apexi rev/speed meter. I got my 1st gen apexi speed meter for 75 shipped.
