Leaky Vtec Solenoid
hmm. i'm not sure where to place this thread but since i have a 98' EK hatch, i might as well put it here
So my motor started leaking oil from the upper Vtec Solenoid gasket, so i went to honda to order a gasket for a 1999 Civic Si, since i assume that the Si's B16A2 Vtec solenoid is the same as my B16A SiR II's solenoid. But i took the gasket home and it didn't fit correctly, i can't return it cuz i already open the package. So i'm wondering which gasket for which car to order now, since the one for the 1999 Si don't work...
gasket looks something like this since i can't take a pic of my actual one
to clarify: it's a special order part cuz no H0nda dealer in So Cal carries it. So i just can't take my old gasket to the dealer and compare it to a new one.*gay* . the gasket i ordered has the same shape as the one from my solenoid, just that it was much thinner, it didn't even fill up the ring gap. when i went to honda, they pulled up a picture of the B16A2 engine and located the exact part. yet it didn't fit
oh by the way, i believe the Canadian SiR is the same as the USDM Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohwtfitstutu »</TD></TR><TR><TD CLASS="quote">
oh by the way, i believe the Canadian SiR is the same as the USDM Si</TD></TR></TABLE>
Silly Canadians
Silly Canadians
yeah. the parts # is 36172-P08-015
i thought it'd come with the gasket and the filter attached inside the 0-ring part of the gasket, but it only came with the bare rubber gasket, no filter
i guess hondabond it is then...
It was coverd here already. I think you have to order the NSX gasket..i unno though. check though. because its on here. im just not sure where.
U need the part # so you can order it too. i dont know it either. hahha
hey u are in luck. I found the link. here you go
I hope it applys.
https://honda-tech.com/zerothread?id=1340039
I hope it applys.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
You should throw a little HondaBond on there anyway, but I replaced the gasket on my B16A SiR II with one from the 94 DelSol VTEC model. Worked like a champ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">You should throw a little HondaBond on there anyway, but I replaced the gasket on my B16A SiR II with one from the 94 DelSol VTEC model. Worked like a champ. </TD></TR></TABLE>
i'll second that, my bro's SiR-II B16 uses Del Sol Vtec replacement parts.
You can order it from any of the following:
http://www.hondapartsdeals.com
http://www.slhondaparts.com
http://www.hondaautomotiveparts.com/home.htm
Just make sure its the VTEC model you order from.
Moi Zver' (GSR)
Dec 3, 2009 01:17 PM
Lightsped
Sep 1, 2009 08:40 AM
