skunk2 stage 2 on ITR springs/retainers???
Old Nov 2, 2005 | 06:33 PM
toda kid's Avatar
Default skunk2 stage 2 on ITR springs/retainers???
im planning to get a skunk2 stage 2 for my b16a with OS PCT pistons and ITR valvesprings and retainers. i dont plan on revving it more than 9000rpm, do you guys think the ITR springs/retainers can hold upto 8600-8800rpm?
need some enlightenment guys. TIA.
Old Nov 2, 2005 | 07:59 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: skunk2 stage 2 on ITR springs/retainers??? (toda kid)
no they wont.
Old Nov 2, 2005 | 08:15 PM
IntegraType-R's Avatar
Default Re: skunk2 stage 2 on ITR springs/retainers??? (PURPLETERROR aka BIGMATT)
lmfao.. my stock ITR springs/retainers held up that high, i only upgraded cause i wanted to rev high i got mine for sale if u want em, 120 shipped to ur door.
Old Nov 2, 2005 | 08:48 PM
UncleD's Avatar
Default Re: skunk2 stage 2 on ITR springs/retainers??? (IntegraType-R)
S2S2's........the most covered, most talked about and popular camshaft profile. You can find everything you're ever wanted to know about them here... https://honda-tech.com/zerosearch
Old Nov 2, 2005 | 10:39 PM
ziggen243's Avatar
Default Re: skunk2 stage 2 on ITR springs/retainers??? (clean rice)
nice! lol
Old Nov 2, 2005 | 10:40 PM
toda kid's Avatar
thanks for the replies.
also the "search" feature doesnt wanna work earlier.
any other experiences with s2 s2 on ITR valvetrain?
Old Nov 3, 2005 | 03:24 AM
808_si's Avatar
why take the risk? if your gonna run stage 2 cams, spend the extra money on your valvetrain.
Old Nov 3, 2005 | 03:29 AM
rodimus's Avatar
Default Re: (toda kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toda kid &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies.
any other experiences with s2 s2 on ITR valvetrain?</TD></TR></TABLE>
well now search wants to work.
if you already have the itr valvetrain, you can get portflow inners/retainers and have a portflow valvetrain. that will be sufficient.
other than that..supertech, toda, omni and rocket's valvetrain come to mind.
Old Nov 3, 2005 | 03:46 AM
crx4life2002's Avatar
Default Re: (EVOL)
I had skunk 2's in my itr crx with crower springs...reving aint the prob its the fact that these cams have higher duration and lift. Reving over the engines power band wont do **** for you.Proper springs and retainers are essential and should never be seconded guessed....
HONDA OEM Civic Type R -11.5mm 243 @ 1mm 10.5 mm 235 @ 1mm
skunks-Skunk2 stage 2 -12.3 mm 266 @ 1mm 11.8 mm 262 @ 1mm
Old Nov 3, 2005 | 04:25 AM
IN VTEC's Avatar
ITR valve springs won't even handle the peak lift of the Skunk2 stage 2's on the HI cam before they bind. You can't universally compare how high people are revving on a given spring/retainer/seat/valve seat position combination without qualifying it with what camshaft is being used.
Old Nov 3, 2005 | 09:23 PM
Default Re: skunk2 stage 2 on ITR springs/retainers??? (IN VTEC)
WRONG...my ITR's handled Stage 2's for quite sometime, i down graded my cam cause i was just tryin to helpa buddy out, and came across the ctr's i have now, but since then i've upgraded my whole valvetrain pretty badass i might add...why i'm looking for stage 3's but i've seen some Stock CTR/ITR valvetrain handle stage 1's.. and some stage2's.. i've seen them handle stage 2 crane cams and toda's but skunk2 i dunno for sure.
Old Nov 3, 2005 | 09:25 PM
but in any case, better to be safe then sorry, i tuned my car for these. and i know my car every car is different so the only way to really be safe is to not second guess, that lope is pretty high on a stage 2.. if ur reving to 9300+ like me, and u only got stock valvetrain and that piston comes up to say hello... that valve is goin to beat the crap out of the piston and your valve is goin to either.
A) float
B) Crack a piston
C) shoot out the top of that block..
Old Nov 4, 2005 | 06:50 AM
NA.GEORGE's Avatar
i run skunk 2 stage 2 cams with my stock itr head 4 6 months and reved it to 9k all day and i never had one problem
Old Nov 7, 2005 | 04:17 PM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">ITR valve springs won't even handle the peak lift of the Skunk2 stage 2's on the HI cam before they bind. You can't universally compare how high people are revving on a given spring/retainer/seat/valve seat position combination without qualifying it with what camshaft is being used.</TD></TR></TABLE>
Exactly, I agree 100%. Integra Type R, if you would run those cams in there for 2 years like I did with ITR springs and then pull your valve cover off and take a real good look at the retainers. You'd see that the springs are going to rip the retainers apart, thats what they did to mine and I had Skunk Ti retainers in there. It litteraly cut the outside ring off of the retainers on 3 of them and had the rest of them paper thin. So you run what you want in your motor, but the power potential and life of the head will be risked if you start cutting corners.
I know a lot of people will agree with me on this. It's much cheaper to do it right the first time.
Old Nov 7, 2005 | 05:07 PM
zap's Avatar
zap
as far as I know Ti retainers needs to be replaced on a certain period coz it deteriorates.
Old Nov 7, 2005 | 06:01 PM
slo blue's Avatar
Default Re: (zap)
depending on motor set up the skunk2 stage 2 will not make peak power til 9k or higher. my last motor with s2s2 started to make good power around 6600 and did not stop til 9300. for how cheap aftermarekt springs are it is not worth the risk to use itr springs imo.
rps_ak
Aug 18, 2006 10:11 AM
-faded-
Aug 17, 2004 04:40 PM
rough_draft
May 9, 2004 06:44 AM
lakerschamp2000
Feb 22, 2004 02:13 PM
StinkyTofu
Feb 25, 2002 10:11 PM
