rotors are rusted to the hub
Old Nov 2, 2005 | 06:20 PM
92 CIVIC HATCH VX's Avatar
Default rotors are rusted to the hub
drilled screws and undid caliper and pounded the crap our the rotor with rubber mallet???? also used a pry bar in the back bracing it on the caliper bolt.
Old Nov 2, 2005 | 06:42 PM
signorelli21's Avatar
yea well i hope you don't plan on having them turned, lol . that **** happened to me when i first got my car, you have to ******* hit them with a sledge hammer on the pad surface to break them loose, or try pounding around the hub part if your afraid of breaking something.
Old Nov 2, 2005 | 07:03 PM
Default Re: (signorelli21)
yeah i would like to have them turned well... crap? my neighbor asked if i need his sledge too? lol
Old Nov 2, 2005 | 07:06 PM
coquitlamEG's Avatar
Default Re: (92 CIVIC HATCH VX)
did you try putting a couple bolts into the threaded holes in the rotor and tightening them to pull it away from the hub?
Old Nov 2, 2005 | 07:10 PM
EG2Driver's Avatar
Default Re: (coquitlamEG)
hit it with a hammer. Rubber mallet if u wanna keep ur rotors.....but they're rusted. Just hit the thing twice, give it a quarter turn and do that. If that doesnt work, ehhhhhhh i dont know man, hit harder. Luck to you bro.
Its cheaper to get new rotors and to get them turned.....look into it.
Old Nov 2, 2005 | 07:11 PM
i think that only works with drum brakes casue thats how i did them. the fronts look like a hole thats through.
Old Nov 2, 2005 | 07:16 PM
a 92 civic should have threaded holes in the rotors as well, unless for some reason some non oem rotors don't have them. Last time i changed my rotors i had the same problem as you. I ended up cranking the bolts until the rotor actually cracked right off.
zero708970
Nov 10, 2008 07:33 PM
zbase
Jun 21, 2007 06:57 AM
Wendys or Bust
Oct 24, 2006 07:11 PM
Knight1
Dec 10, 2005 09:35 AM
pcorad
Sep 17, 2001 05:09 PM
