--D16Y8 Into Del Sol--??
Old Nov 2, 2005 | 05:40 PM
Arsenal's Avatar
Default --D16Y8 Into Del Sol--??
Yes I searched, but
Will a D16Y8 go straight into a 93 Del Sol? IS the Del Sol already wired to accept it ect.?
And need the specs for it.
Thanks
Old Nov 2, 2005 | 07:42 PM
Asway's Avatar
Default Re: --D16Y8 Into Del Sol--?? (Arsenal)
well iam no expert by ne means but i think a y8 is an obd2 ecu and the delsol has obd1 so you may have some switching aroud with your wireing to do
Old Nov 2, 2005 | 08:32 PM
Stoich EG2's Avatar
Default Re: --D16Y8 Into Del Sol--?? (Asway)
yes it will go straight in using your existing mounts. you will have to use your del sol shift linkage though. and like the guy above said, you're going to need a obd1->obd2 harness
Old Nov 2, 2005 | 08:33 PM
1993civicex's Avatar
just go d16z6 there a better engine than the y8 the y8 and y7s were set up mainly for fuel ecnomy...but to get extra horses upgrade the injectors and get the y8 intake mani...or do what im doing build yourself a d16z6..........but if u really want the y8 all u have to do is keep ur computer and change the distributor
Old Nov 2, 2005 | 08:35 PM
sockvtec's Avatar
Default Re: --D16Y8 Into Del Sol--?? (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex &raquo;</TD></TR><TR><TD CLASS="quote">just go d16z6 there a better engine than the y8</TD></TR></TABLE>
haha dont start that expletive expletive you expletive
Old Nov 3, 2005 | 04:35 AM
Arsenal's Avatar
Default Re: --D16Y8 Into Del Sol--?? (sockvtec)
Well I would rather have more concrete answers....
Thanks though
DualCamEJ
Mar 23, 2010 01:31 AM
sde780
Oct 13, 2009 04:54 PM
GoHardEH2
May 21, 2007 08:30 PM
delsoldrew
May 23, 2006 12:04 PM
elniko
Jan 17, 2005 01:52 PM
