Timing belt
Old Nov 2, 2005 | 04:37 PM
Cooker4418's Avatar
Default Timing belt
My 94 integra has about 95k miles on it and im not sure or not if the last owner replaced the timing belt or not...is there a way I can check and see if it needs to be changed or if it has been recently?
Old Nov 2, 2005 | 05:19 PM
Racermech's Avatar
Default Re: Timing belt (Cooker4418)
not really, even if it looks good it could be old and about to break/shread.
When i doubt.........replace it
Old Nov 2, 2005 | 05:29 PM
Cooker4418's Avatar
Default Re: Timing belt (Racermech)
yeah thats probably a good idea... what an expensive pain in the *** though.
Old Nov 2, 2005 | 06:41 PM
SOHCVTECx2's Avatar
If anything just change it if you feel unsecrure about it. I made my mistake by not changing the belt and blew my motor. If i were you rite now i would definitely change it.
Old Nov 2, 2005 | 07:30 PM
SOHCD16y8's Avatar
Default Re: (SOHCVTECx2)
Yeah and do the water pump while your in there. Altogether your lookin at a couple hours of work and like 75 bucks.
Old Nov 2, 2005 | 08:10 PM
Cooker4418's Avatar
Is it possible to do the timing belt on your own? I know the timing belt isnt all that expensive but the labor part is....and how about the water pump?
Old Nov 3, 2005 | 10:22 AM
kon's Avatar
kon
same problem as Cooker(don't know if previous owner changed it or not)... but 97 gsr with 96k.
Old Nov 3, 2005 | 10:44 AM
HONDA RR's Avatar
Your just better of replacing it just to be safe.
Old Nov 3, 2005 | 11:42 AM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cooker4418 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to do the timing belt on your own? I know the timing belt isnt all that expensive but the labor part is....and how about the water pump?</TD></TR></TABLE>
yes it's doable if you have done quite a bit DIY and have proper tools.
http://www.c-speedracing.com/h...t.php
IM me if you have specific questions
allen1466
Honda Civic (2001 - 2005)
Jul 10, 2008 06:36 PM
tomcool
May 14, 2007 08:40 PM
honda94accord
Apr 10, 2007 05:39 AM
TeGGY_LS
Mar 5, 2004 11:28 PM
animated_life
Oct 22, 2002 09:48 PM
