Suspension Techniques Rear sway bar install?
Old Nov 2, 2005 | 03:18 PM
HondaPartsHero's Avatar
Technical Hero
Default Suspension Techniques Rear sway bar install?
I'm helping a friend out with this 89 Si installing the front and rear sway bars. We got the fronts on with no problem. The rears look a little tougher but ST's instructions are a little how should I say crappy. I can't really get a good idea of how the bracket bolts to the control arm shock bolt. Does anyone have either a page they know of with a good write up with pics. Or can someone take some good pics of their rear bar at the control arms so I can see how it installs a little better.
Old Nov 2, 2005 | 03:29 PM
rsca_crx's Avatar
Default Re: Suspension Techniques Rear sway bar install? (yebabee)
here is a thread with a lot of links in it to various solutions. i didn´t pull out specific links because there is more than one way to skin this cat and i don´t know more about your shock or control arm setup.
https://honda-tech.com/zerothread?id=1412964
Old Nov 2, 2005 | 03:39 PM
APEX CRX's Avatar
here's a pic of mine. not the best angle but gives you an idea
Old Nov 2, 2005 | 03:54 PM
Technical Hero
http://www.gearz.org/Fun/Proje...r.htm
this page solved it all, thanks for all the help!!
Old Nov 2, 2005 | 04:08 PM
APEX CRX's Avatar
Cool. hey I remember you now. I sold you rear LCA's off my CRX !!
Old Nov 2, 2005 | 04:34 PM
Technical Hero
Default Re: Suspension Techniques Rear sway bar install? (APEX CRX)
Wow thats some good memory!! Yeah I used them as spares to get the bushings pressed out for my 89 CRX Si to put in the Energy Suspension ones in. I've since sold the car to a friend and am helping him learn to do some work on it. Since he bought it he painted it white, I helped him put a b16a in it, helped him put tokico's all the way around, and he recently bought the sways and we're learning together since this is the first time any one of us has done this. The next project is to swap the rear discs off a wrecked 91 Si we found. Thanks APEX, seller!
Old Nov 2, 2005 | 05:03 PM
hughesl's Avatar
What brand are those lower control arms?
How much weight did you save over stock?
Old Nov 2, 2005 | 05:30 PM
Pee Wee's Avatar
Default Re: Suspension Techniques Rear sway bar install? (hughesl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hughesl &raquo;</TD></TR><TR><TD CLASS="quote">What brand are those lower control arms?
How much weight did you save over stock?</TD></TR></TABLE>
function7 and they weight 2lbs a piece i think
fourthgenhatchB17's Avatar
Function7. Super duper light compared to the stocks.
Edit: damn dude above me beat by like seconds! Anyways, does anyone else's endlinks make a lil bit noise??
Modified by fourthgenhatchB17 at 2:44 AM 11/3/2005
Old Nov 2, 2005 | 05:48 PM
Pee Wee's Avatar
Default Re: Suspension Techniques Rear sway bar install? (fourthgenhatchB17)
88 style function7 = 2.5lbs $250.00
89-91 function7=2lbs $200.00
and an endless supply of bling factor
Old Nov 2, 2005 | 06:36 PM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by fourthgenhatchB17 at 2:44 AM 11/3/2005</TD></TR></TABLE>mine do but i think it's becasue i'm not using the "self luberating" endlinks that come with the kit
Old Nov 2, 2005 | 07:34 PM
RapeV-8's Avatar
can u take sum pics of the front for me??? i have problems installing mine ST!!!
Old Nov 2, 2005 | 08:36 PM
90civichbsi's Avatar
Default Re: (igotcrx)
a lil OT but is there any way of that bar clearing a 3" exhaust?. has anyone come up with any solutions?
Old Nov 2, 2005 | 08:41 PM
turbodcivic510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">here's a pic of mine. not the best angle but gives you an idea
vee next time you go to a track event i want a ride!!!!
ps this is turbodcivic(richard) from NCCC
Old Nov 2, 2005 | 09:44 PM
jisu009's Avatar
Default Re: Suspension Techniques Rear sway bar install? (EF8opey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">88 style function7 = 2.5lbs $250.00
Taking a 2lb **** for free....PRICELESS!
Old Nov 2, 2005 | 09:59 PM
mikerbike's Avatar
Default Re: Suspension Techniques Rear sway bar install? (jisu009)
He said they weigh 2 lbs a piece, not save 2 lbs a piece. I think stock RLCAs weigh a bit more than 3 lbs...
Old Nov 2, 2005 | 10:01 PM
jisu009's Avatar
Default Re: Suspension Techniques Rear sway bar install? (mikerbike)
I have one in the garage....I promise it doesn't weigh that much more. For the increased chance of snapping the LCA as opposed to bending it...I will stick to stock.
Pee Wee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">
Taking a 2lb **** for free....PRICELESS!</TD></TR></TABLE>
lmao mang
Old Nov 3, 2005 | 01:46 AM
Technical Hero
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">can u take sum pics of the front for me??? i have problems installing mine ST!!!</TD></TR></TABLE>
the front sways bars?
I did this. On the frame bushings put them together and put on the bar. Place the little metal clip from the frame bushing holder in the hole in the car but don't put the bolt in yet. Now assemble and bolt up but don't tighten the endlinks as shown above on both sides. Now bolt up the frame bushing section one side at a time, it will be tough but you will have to push up real hard. Next bolt down both endlink sides tight enough till the bushings bulge but don't crush them.
Old Nov 3, 2005 | 05:25 AM
RapeV-8's Avatar
i have problems with the front bushing and the 2 bracket in the sub frame?! i cant put the o.e bracket on because the sway bar are too FAT
Old Nov 3, 2005 | 08:50 AM
Technical Hero
Hmm...I just put the fronts on yesterday and they were a little small going on there but I just put the bushing on the bar first then the bracket. It is a little small but it will go on. It helped that I used my cordless impact to get the bolt pushed up enough to start it but it should work.
Old Nov 3, 2005 | 05:24 PM
Default Re: Suspension Techniques Rear sway bar install? (onePOINTsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix &raquo;</TD></TR><TR><TD CLASS="quote">mine do but i think it's becasue i'm not using the "self luberating" endlinks that come with the kit</TD></TR></TABLE>
See those endlinks that came with the bar are ****, and still made noise. They developed sooo much play in them.
Old Nov 3, 2005 | 06:23 PM
CRXBart's Avatar
fourthgenhatchB17, sweet you actually have me quoted in your sig, thats a first.
Old Nov 3, 2005 | 06:57 PM
RapeV-8's Avatar
any1 got a pic for the front sway bar?
Old Nov 3, 2005 | 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">any1 got a pic for the front sway bar?</TD></TR></TABLE>
There is one already, look up about 4 or 5 posts.
The only confusion would be for the endlink...i hope you're not having trouble bolting it to the body.
