Piston to valve clearance?
Old Nov 2, 2005 | 03:18 PM
nah22accord's Avatar
Default Piston to valve clearance?
I have a fully built h22a. The block is built and sleeved by Golden Eagle: stock crank, JE 11.5:1 comp pistons, eagle rods. All are std bore and size. The head was done by Portflow: has dual vavle springs titanium retainers and REV valves which are all std. size vavles. They did not mill anything off the block or head, just resurfaced it, and has the std thickness cometic head gasket. Wanting to know if you think the piston to valve clearance should be looked over. I was told I shouldnt have anything to worry about since it is the stock crank, bore, valves, headgasket and the block and head were not milled. Just trying to get some more feedback on this. Thanks..
Old Nov 2, 2005 | 04:19 PM
thedread's Avatar
You should not have anything to worry about, but you might want to check out clearances just to be safe. Resurfacing a head can cause removal up to .010 of material depending on the condition of te head.
Old Nov 2, 2005 | 04:58 PM
Default Re: (thedread)
Hopefully It wont. Thanks for the input.
Old Nov 2, 2005 | 08:54 PM
The Captain's Avatar
Default Re: (nah22accord)
with that setup, about what kinda whp are you expecting?
Old Nov 4, 2005 | 03:46 PM
Default Re: (98silverlude)
Think, maybe 240-whp
monster_c
Jan 12, 2012 10:48 PM
Christopherian1982
Feb 26, 2009 05:42 AM
NewOrleansH22
May 4, 2005 01:57 PM
ScottEK
Dec 3, 2004 12:55 PM
