how can i get more shock travel?
Old Nov 2, 2005 | 02:32 PM
wu tang's Avatar
Default how can i get more shock travel?
i have the blue tackico struts and im tired of bottoming out
bump stops are cut very small
Old Nov 2, 2005 | 02:36 PM
GroundZer0 336's Avatar
Default Re: how can i get more shock travel? (wu tang)
you can put 89 accord front struts on a crx. theyre like 2 inches shorter. you can also extend the top mount of where the strut piston mounts to the car by cutting the mount in half and welding some tubing between the 2 sections.
OR you can get some coilovers and/or raise your car up but its up to you.
Old Nov 2, 2005 | 02:59 PM
Boosted Chemist's Avatar
Default Re: how can i get more shock travel? (GroundZer0 336)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroundZer0 336 &raquo;</TD></TR><TR><TD CLASS="quote">you can put 89 accord front struts on a crx. theyre like 2 inches shorter. you can also extend the top mount of where the strut piston mounts to the car by cutting the mount in half and welding some tubing between the 2 sections.
OR you can get some coilovers and/or raise your car up but its up to you.</TD></TR></TABLE>
blues do suck, that top hat mount seems promising, im thinking of trying it out soon.
Old Nov 2, 2005 | 03:01 PM
Tyson's Avatar
https://honda-tech.com/zerothread?id=469485
zoomhonda
May 13, 2010 02:07 PM
fastcrx420
Mar 14, 2006 05:52 PM
CantKnckDaHustle
Jan 12, 2006 02:06 PM
11seclude
Welding / Fabrication
May 4, 2005 02:42 PM
hondapwred95
May 2, 2005 05:29 PM
