Honda S2000 Honda S2000
what spark plugs are you guys using......
Old Nov 2, 2005 | 02:28 PM
H2nr's Avatar
Default what spark plugs are you guys using......
for your turbo or supercharged S2k?
Old Nov 2, 2005 | 02:36 PM
WowOzYouRock's Avatar
Default Re: what spark plugs are you guys using...... (H2nr)
oem
Old Nov 2, 2005 | 02:40 PM
H2nr's Avatar
Default Re: what spark plugs are you guys using...... (Y2K_S2K)
really, why would you not run a colder plug?
Old Nov 2, 2005 | 02:45 PM
cuz the spark is control with the ecu ... f20c doesnt have distributor
help me out guys .. im talking outta my ***
i heard s2000 doesnt like diff kind of spark plug unless its oem NGK platinum or denso platinum
Old Nov 2, 2005 | 02:47 PM
Nishant's Avatar
^ is correct for a NA or stock set up
for SC or turbo with high boost, a colder plug is better
if you are running the boost the SC comes set at, like 4.5 or 5.5, whatever it is, oem plug is better. the comptech and vortech SC's are set up that way
edit - when i say high boost, we're talking 600+ hp
Old Nov 2, 2005 | 02:51 PM
Default Re: what spark plugs are you guys using...... (Nishant)
nishant ure confusing ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">^ is correct for a NA or stock set up</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">if you are running the boost the SC comes set at, like 4.5 or 5.5, whatever it is, oem plug is better. the comptech and vortech SC's are set up that way</TD></TR></TABLE>
Old Nov 2, 2005 | 03:34 PM
papa5murf's Avatar
comptech = 6/7psi
vortech = 7/8psi
use colder plugs when you're boosting, use oem plugs if you're staying na...
Old Nov 2, 2005 | 03:35 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">nishant ure confusing ...
who said i wanted to make it easy
Old Nov 2, 2005 | 03:52 PM
revhi's Avatar
Denso IK24, but I here Copper is better.
Old Nov 2, 2005 | 05:02 PM
H2nr's Avatar
Default Re: (revhi)
does anyone have a colder NGK plug number? This s2000 will be running 10psi from a t3/t4 on a stock engine.
Old Nov 2, 2005 | 06:02 PM
Moemers's Avatar
Default Re: (H2nr)
10 psi on a stock motor? j00 crazeee
Old Nov 2, 2005 | 06:10 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (RWD_Honder)
On a T04/T3, even crazier!
Old Nov 7, 2005 | 06:51 AM
H2nr's Avatar
Default Re: (Slideways2000)
come on guys I know someone knows of a one step colder plug from NGK
Old Nov 7, 2005 | 09:08 AM
Nishant's Avatar
Default Re: (H2nr)
are you need of colder plugs?
Old Nov 7, 2005 | 09:35 AM
* B A N N E D *
Default Re: (Nishant)
Isn't there a CDI out there called IcePak? Doesn't that make your plugs colder?
I'm breaking my correct-info streak.
The Collin
Oct 1, 2007 05:50 PM
Devo94ac
Nov 2, 2005 08:53 AM
booscivic
Jan 20, 2004 10:27 AM
gassinit
Dec 12, 2003 05:48 PM
reditr
Nov 12, 2003 12:58 PM
