Why the power loss?
Old Nov 2, 2005 | 02:05 PM
hybridmiklo's Avatar
Default Why the power loss?
I can't exactly figure out why my motor puts out such low power. Hopefully an experienced person here can help me out. Here is the setup:
2nd gen b16, obd 0 pr3 ecu with mugen chip, vtec controller,
aem cai, spoon t-body, itr intake manifold with hondata gasket, skunk2 stage 2 cams + valvetrain, spoon cam gears, banged up dc 4-1 header, tanabe exhaust, hollowed cat, ngk plugs and wires, also have aem regulator and rail.
The motor put out 147hp and 103tq at hook-ups dyno. Is also tuned by Church. Could someone explain why the power output is so low and what I can do to help it. It runs good, I compression tested it at 190 all 4 cylinders.
Thanks for the time
Old Nov 2, 2005 | 08:43 PM
cpforyou's Avatar
Default Re: Why the power loss? (hybridmiklo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote">I can't exactly figure out why my motor puts out such low power. Hopefully an experienced person here can help me out. Here is the setup:
Thanks for the time</TD></TR></TABLE>
First of all, what did it do on Church's dynapack?
Old Nov 3, 2005 | 08:26 AM
StyleTEG's Avatar
Spoon TB is 70mm, way too big
A hollowed cat is still only 2" inlet and 1.8" outlet, way too small
Not enough compression for stage 2 cams
Old Nov 3, 2005 | 03:49 PM
Default Re: Why the power loss? (StyleTEG)
On the dynopak it put out 168hp. I forgot to mention that I also have a mugen headgasket which is said to raise compression.
civic j
Sep 10, 2007 09:16 AM
tomlinson619
Mar 15, 2006 11:47 PM
hybridmiklo
Mar 24, 2005 09:26 PM
anothersickhatch
Aug 6, 2004 08:55 PM
vtecludeh22
Apr 8, 2004 10:26 AM
