5th Gen Prelude Auto to Manual swap
Old Nov 2, 2005 | 01:29 PM
bigtimlikewhoa's Avatar
Default 5th Gen Prelude Auto to Manual swap
Hello.. i know i've made this topic before and so has other members.. i just cant seem to find them again for me to go look at.. soo I need the guide to do a flawless 5spd swap on a 5th gen prelude.. and tips.. do you recommend doing the swap? is it worth it? what would i need? alrgiht.. i really do need all the help i can get.. thanks!
Old Nov 2, 2005 | 05:44 PM
onefastrx7turbo's Avatar
Default Re: 5th Gen Prelude Auto to Manual swap (bigtimlikewhoa)
sell the car and buy a manual...
Old Nov 2, 2005 | 08:12 PM
Default Re: 5th Gen Prelude Auto to Manual swap (onefastrx7turbo)
nah.. i'd never sell my car.. gone through too much for it.. rather swap and keep than sell..
Old Nov 2, 2005 | 08:16 PM
come on.. 33 views and no replies? i need help
Old Nov 3, 2005 | 12:54 AM
K-Spec's Avatar
first: if you don't have a helms manual, get one!
second: here is the link http://www.mazmo.com/zameoj/swap.htm
read that and if you have questions, just ask
goodluck
Old Nov 3, 2005 | 03:27 AM
Default Re: 5th Gen Prelude Auto to Manual swap (khalal538)
i have the helms manual already =] and yeah thats the site i was looking for! thanks a lot!
Modified by bigtimlikewhoa at 5:11 AM 11/3/2005
Old Nov 3, 2005 | 05:32 AM
doctorcarta's Avatar
my local shop will do it on my 98 s for $2,000+labor;i think that is negotiable...
Old Nov 3, 2005 | 08:50 AM
K-Spec's Avatar
Default Re: (doctorcarta)
does that include parts? look to have about $4000 on hand.
Old Nov 3, 2005 | 07:34 PM
Default Re: (khalal538)
damn.. $2000 + labor? isnt that kinda expensive? i doubt all the parts will exceed $1200..
Old Nov 3, 2005 | 08:26 PM
K-Spec's Avatar
Default Re: (bigtimlikewhoa)
it will exceed $1200 easily and for sure (unless you can find a front clip from a junkyard maybe). New clutch kit alone goes for $300-$400, plus you need a flywheel and that's another $200-$300. You're already at $500-$700 and that doesn't even include the tranny and other parts (such as the clutch pedal assmbly, brake pedal assmbly, shifter assmbly and cables, etc).
Old Nov 3, 2005 | 08:43 PM
oh.. well yeah thats true if you want to get like the badass clutch and flywheels right away.. i was actually thinking going all oem first to break in everything b4 putting those and racing the **** outta the newly swapped car ya know..
Old Nov 3, 2005 | 08:54 PM
K-Spec's Avatar
are you buyin a brand new tranny?
Old Nov 3, 2005 | 09:05 PM
oh nawww.. used one.. i dont need a new one.. i dont even think i could get a new one.. probably a rebuilt one.. but not a new one..
Old Nov 3, 2005 | 09:34 PM
K-Spec's Avatar
then in that case, the only thing you have to break-in is the clutch and the flywheel.
Old Nov 4, 2005 | 07:24 AM
DarthLuder's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastrx7turbo &raquo;</TD></TR><TR><TD CLASS="quote">sell the car and buy a manual...</TD></TR></TABLE>
good advice.
Old Nov 4, 2005 | 07:39 AM
mgags7's Avatar
^^not good advice....a manual swap is simple....people just hype it all up....
you need to buy:
ANY h series tranny, the amount of money you spend is up to you, but the cheapest you will find will probably be an h23 tranny for like $400
clutch master and slave cylinders - $100 new
clutch hard line from master to damper, the damper, and soft line to slave - $50 most at a junkyard
pedal assembly - $50 at a junkyard
shifter - $50
cables - $75
total: $725 in parts
$0 in labor with testacles
$1500 if you dont have them
if you must have it:
gauge cluster out of a manual - $100 (+-, i dont know)
good luck
Old Nov 4, 2005 | 09:33 AM
SteveoBA8's Avatar
Default Re: (mgags7)
Do the conversion.
Old Nov 4, 2005 | 12:11 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">$725 in parts
and that doesn't include the clutch and fly...
Old Nov 4, 2005 | 12:18 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">^^not good advice....a manual swap is simple....people just hype it all up....
agreed
when you've already modded your car so much, it would be more expensive (both time and money) to sell your auto and trying to find and buy a 5spd and exchange parts. If you have mechanical skills and a friend to help you, the swap should be fine. Took me 2 weeks, had to wait for parts to come in. The hardest parts of the swap I would say is making three holes in the firewall for the MC and trying to get the tranny through from the bottom using only jackstands. After it's done, it is well worth it.
Old Nov 4, 2005 | 12:25 PM
SteveoBA8's Avatar
Running the pre-bend clutch hard was a biatch on my 4th gen but 100million% worth it to do an auto to manual swap. Arm yourself with a manual and beer( for afterwords) That sucks for you 5th gen guys having to cut holes for the mc but its just more time.
Im using the jdm clutch pedal assembly in my 4th gen and it has no provision for the starter cut switch( it has the switch for the cruise but i guess they dont care if someone runs their car through a garage?) So instead i installed a hidden startercut switch good theft deterrent( thieves i own guns and am not a nice guy so dont even try it)
Old Nov 4, 2005 | 07:13 PM
K-Spec's Avatar
Default Re: (SteveoBA8)
i gotta kill switch too
Old Nov 4, 2005 | 07:23 PM
92hondalude's Avatar
i got a sh tranny for sale fore $450
Old Nov 4, 2005 | 09:25 PM
Default Re: (92hondalude)
can SH tranny work without its ATTS? i mean i know its just an attatchment but i'm just puzzled about that.. i really dont want an sh tranny if it'll only work with atts..
Old Nov 5, 2005 | 11:39 AM
bstlude's Avatar
only problem i see is that the shifter cables are more than $75 new from honda. There is no way i would buy used shifter cables cause you do not know how they were treated before you got them. My cables from my prelude lasted 30000miles before they stretched.
Old Nov 5, 2005 | 03:30 PM
Default Re: (bstlude)
shifter cable more than $75 from honda? is that same as shift linkage? sorry for that dumb question cuz b4 i was talkin to someone about shifter cables and i dont remember if they're the same or not.. but anyways soo how much do they really run? do you know the exact price? alright thanks!
