Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
More LSD talk
Old Nov 2, 2005 | 11:08 AM
bosco500's Avatar
Default More LSD talk
The last race at Rockingham I wasn't too pleased with how my diff was performing. I decided to go ahead and pull the tranny for rebuild, and am seriously considering just welding the thing up to see if I like it or not. I've seen old ford diff's welded, but just want to make sure I hit it in the right spot. What is the best way to weld it up? Its a stock R diff.
Old Nov 2, 2005 | 11:17 AM
EdoMoto's Avatar
Default Re: More LSD talk (bosco500)
Get a spool. So in case u dont like it you can put in the R diff back in.
Old Nov 2, 2005 | 12:10 PM
rotten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">The last race at Rockingham I wasn't too pleased with how my diff was performing. I decided to go ahead and pull the tranny for rebuild, and am seriously considering just welding the thing up to see if I like it or not. I've seen old ford diff's welded, but just want to make sure I hit it in the right spot. What is the best way to weld it up? Its a stock R diff.</TD></TR></TABLE>
First thing you need to do is get an open differential that fits your ring gear. You don't want to weld the type r diff.
At a minimum you want to weld the spider gears together like in the picture. You can also weld the gears to the housing.
Try not to heat the unit up too much, as it can warp.
Old Nov 2, 2005 | 12:36 PM
bosco500's Avatar
Default Re: More LSD talk (rotten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotten &raquo;</TD></TR><TR><TD CLASS="quote">
Try not to heat the unit up too much, as it can warp.</TD></TR></TABLE>
Thanks for the info and the pic.
Old Nov 2, 2005 | 12:38 PM
.RJ's Avatar
.RJ
wrong link on the pic - http://www.fatboyraceworks.com...4.jpg
Old Nov 2, 2005 | 03:51 PM
Mr.Noodles's Avatar
Default Re: More LSD talk (.RJ)
If you're going to weld it up, make sure you insert the axles into the diff prior to welding and then weld the spider gears. It won't transfer enough heat to the axles to screw them up and ensures the welded diff's splines will line up with the axles when installed.
Old Nov 3, 2005 | 03:48 AM
Honda318dx's Avatar
Default Re: More LSD talk (Mr.Noodles)
spools are cheap and cut down on rotational mass..
Old Nov 3, 2005 | 09:18 AM
Type_RS_59's Avatar
I'll trade ya for a stock '98 Integra RS open diff. It's already out of the car and ready to go.
Old Nov 3, 2005 | 12:49 PM
.RJ's Avatar
.RJ
Default Re: More LSD talk (Type_RS_59)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_RS_59 &raquo;</TD></TR><TR><TD CLASS="quote">
I'll trade ya for a stock '98 Integra RS open diff. It's already out of the car and ready to go.</TD></TR></TABLE>
That wont fit - ring gear patterns are different, he'll need a GSR diff.
Old Nov 3, 2005 | 02:33 PM
bosco500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">That wont fit - ring gear patterns are different, he'll need a GSR diff.</TD></TR></TABLE>
What he said
turbo16rex
Jan 27, 2007 05:43 PM
crxpwr1
10
Jun 22, 2006 11:12 AM
pr1mo_13
Dec 22, 2005 06:54 PM
integlspwr2k
Jan 4, 2005 01:10 PM
kaoss_11
18
Jul 9, 2004 07:44 PM
