The Steps For Engine Swaps..Tools...
Old Nov 2, 2005 | 10:29 AM
Goodbye My Love's Avatar
Default The Steps For Engine Swaps..Tools...
I Have a 93 Civic..Soon To Swap Out Motor..Wanted To know The steps to removing the motor and How To Install..Help!! If Anyone Can Find The Links Please Leave it..Thanks
Old Nov 2, 2005 | 10:31 AM
whoDAT's Avatar
Default Re: The Steps For Engine Swaps..Tools... (Long Live Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Long Live Eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> If Anyone Can Find The Links Please Leave it..Thanks</TD></TR></TABLE>
why don't you try to find it yourself
Old Nov 2, 2005 | 12:29 PM
dohcdelsol's Avatar
Default Re: The Steps For Engine Swaps..Tools... (whoDAT)
List of Tools (not complete)
10mm socket and wrench
12mm
14mm
17mm
19mm
21mm
32mm (axle nut)
Center punch for that pesky shift linkage pin
Jack/Jack stands
Cherry Picker if needed
Disconnect battery, intake, header/exhaust. I found it easier to remove bumper and hood so you dont scrape anything. Drain oil and coolent. Disconnect coolent lines from engine to rad. Disconnect fuel lines, disconnect harness either from engine itself or from main fuse box. Pull axles from tranny. Disconnect shift linkage. Set up cherry picker. Disconnect motor mounts. Pull engine.
Thats about it in a nut shell and about 5 minutes of thinking. I know i missed alot so anyone else feel free to add
Old Nov 2, 2005 | 12:32 PM
IHateJDM's Avatar
Default Re: The Steps For Engine Swaps..Tools... (dohcdelsol)
1. find phone book
2. call a shop
3. take car to said shop and drop off
4. take motor to said shop
5. pay them for their expertise
If you have to ask this question, you're no where near ready to swap.
Old Nov 2, 2005 | 12:35 PM
Stoich EG2's Avatar
Default Re: The Steps For Engine Swaps..Tools... (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">If you have to ask this question, you're no where near ready to swap. </TD></TR></TABLE>
people need to buy a Helms THEN ask Honda-Tech
FalkenSiR's Avatar
Old Nov 2, 2005 | 12:36 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT &raquo;</TD></TR><TR><TD CLASS="quote">
why don't you try to find it yourself </TD></TR></TABLE>
you see, is this necessary, so the guy is a noob. just point him in the right direction and thats it, its really not that hard!
Old Nov 2, 2005 | 12:37 PM
whoDAT's Avatar
Default Re: The Steps For Engine Swaps..Tools... (fast88std)
Did you really think Honda-Tech was the EASY way out?
Old Nov 2, 2005 | 12:39 PM
riceburnerryan's Avatar
jsut disconnect everything
Old Nov 2, 2005 | 12:42 PM
IHateJDM's Avatar
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">jsut disconnect everything
true, swapping out the old motor is the easy part, just disconnect it all and pull it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
you see, is this necessary, so the guy is a noob. just point him in the right direction and thats it, its really not that hard!</TD></TR></TABLE>
you're right, that's not necessary, but a helms is 'hint hint'.
Old Nov 2, 2005 | 12:45 PM
haveaniceday's Avatar
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">
people need to buy a Helms THEN ask Honda-Tech</TD></TR></TABLE>
Old Nov 2, 2005 | 01:18 PM
philosofy1's Avatar
no, but sometimes people have easier ways to do things and suggest them on here. besides the manuals dont always tell you everything, or the simplist ways to do them. granted he should of did a search, or read the swap guide on top of the forum, but thats it. all they need is some redirection.
Old Nov 2, 2005 | 01:22 PM
marshun's Avatar
Default Re: The Steps For Engine Swaps..Tools... (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">no, but sometimes people have easier ways to do things and suggest them on here. besides the manuals dont always tell you everything, or the simplist ways to do them. granted he should of did a search, or read the swap guide on top of the forum, but thats it. all they need is some redirection.</TD></TR></TABLE>
the manual wont tell you everything because you SHOULD have basic mechanical knowledge.
think of it like this...you want the motor disconnected from the car correct? then you disconnect everything that connects the motor to the car. leave passenger and drivers side mounts last.
hows that?
Old Nov 2, 2005 | 01:26 PM
philosofy1's Avatar
Default Re: The Steps For Engine Swaps..Tools... (marshun)
relax homie, i know how to do the swap, i've done before, long live eg6 doesnt.
Old Nov 2, 2005 | 01:29 PM
JDM-EJ1's Avatar
Refer to this expletive face: https://honda-tech.com/zerothread?id=1419175.
This sounds right.
12mm
14mm
17mm
19mm
21mm
32mm (axle nut)
Jack/Jack stands
Old Nov 2, 2005 | 01:30 PM
IHateJDM's Avatar
the other problem long live eg6 will have is that when he's done and it doesn't crank, he won't know where to start. Sure you can get advice here on H-T, but if he doesn't know what he's doing, all the e-knowledge in the world won't save him. A helm's is a good place to start, but its not all he'll need to swap a motor.
Old Nov 2, 2005 | 05:56 PM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">relax homie, i know how to do the swap, i've done before, long live eg6 doesnt.
i was just adding on to what you said and trying to clear some stuff up.
im not on this board to undermine anyone
Old Nov 2, 2005 | 06:00 PM
HBADGE's Avatar
Whats helm?
Old Nov 2, 2005 | 06:10 PM
Luserkid's Avatar
Default Re: The Steps For Engine Swaps..Tools... (HBADGE)
http://www.c-speedracing.com/h...p.php
Honestly you need to research more. But that link above is a good start for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBADGE &raquo;</TD></TR><TR><TD CLASS="quote">Whats helm?</TD></TR></TABLE>
Helms is the book of the mechanic gods. It tells you everything and anything you need to know about your car in very well detail. To get go here:
http://www.helminc.com
Old Nov 2, 2005 | 07:13 PM
.Ry's Avatar
.Ry
Default Re: The Steps For Engine Swaps..Tools... (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.helminc.com</TD></TR></TABLE> I just got mine and all I can say is wow.
Old Nov 2, 2005 | 07:19 PM
hitvtecgetloud09's Avatar
Default Re: The Steps For Engine Swaps..Tools... (turner7205)
u guys forgot the most important tools
hammer...breaker bar... and crowbar
and as far as on the how to..just un screw unplug open every thing... its pretty easy once u start
Old Nov 2, 2005 | 09:03 PM
ek82's Avatar
ttt
Old Nov 2, 2005 | 09:17 PM
Stoich EG2's Avatar
Default Re: (ek82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek82 &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
y....
sde780
Jul 8, 2009 10:51 AM
lsvtecej95
Aug 29, 2008 07:11 PM
B18CYAAA
Apr 27, 2006 11:44 AM
mykem
19
Aug 15, 2004 02:00 PM
raymas8
Jul 10, 2004 09:33 PM
