How much would this be worth?
I have been thinking the last few days that if I restore my crx if I could ever get the money back I will have put into it, how much would you personaly pay, and do you think I could sell it?
I will be completely stripping the whole car.. everything, and puting it on a 'car rotisery' so I can properly paint/coat the underside of the car. I would fix all the rust (rear quarters and a little in the rocker pannles) properly by plasma cutting it out and welding in new metal and using as little body filler as possible. I would coat the wheel wells, and whole under side of the car with POR 15, and some other stuff called 'Lizard Skin' that is almost I guess rubbery to quite the whole car down.
I would also repaint the whole car, inside and out.
1990 CRX DX
Engine:
D16Z6 Completely rebuilt (gaskets, water pump, oil pump, alt. etc.)
Ported head
AEM cam gear
Eagle H beam rods
Suzuki Vitara pistons
Polished crank
New OEM bearings
ARP Head studs, and rod bolts
ACT Stage 3 clutch
11 pound flywheel
SI tranny
Ported intake manifold (cut open and runners ground out and properly welded back to gether)
Ported Throttle body
RC 550cc Injectors
AEM Fuel Rail, Fuel Reg.
Vortex FMU
Garrett T3/T04e running 17lbs.
OBX manifold re-enforced
Drag Intercooler (27"x7"x3")
Custom made intercooler sprayer with 2lb C02 Tank (like NX 'N-tercooler')
Greddy type RS BOV
Tial 35mm wastegate
3" Downpipe out a custom 3" exhaust with Apexi N1 Muffler
Fluidyne half sized radiator
Custom oil catch can
NGK High Performance wires
NGK two step colder spark plugs
Short Shifter
Wheel hop bar
Energy Suspension Motor mount inserts
Electronics:
OBD1
P28 ECU
Apexi VAFC
Greddy Turbo Timer
Electronic Boost controler
Autopage Alarm
Interior:
Tenzo R racing seat
Si passenger seat
4pt harnesses
4pt Roll bar with harness bar
Battery relocated to hatch
Autometer gauges (5" tach, boost, oil pressure, a/f, water temp, volt)
Kenwood deck
Kenwood amp
12" Sub
JBL 6.5" front and rear speakers
new red carpet (like CTR)
New headliner
Knockoff JDM bride stearing wheel (with quick relese)
Greddy shift ****
Aluminum pedals
Ractive E-brake handle
Mint condition Climate controls
Suspension/Wheels:
Front and Rear, Upper and Lower Strut bars
16" ADR rims
Rear disc conversion
Brembo slotted and cross drilled rotors
Integra Brake booster
Tein Basic Damper Kit
Ingalls Front Adjustable Camber Kit
Ingalls Rear SmartArm Adjustable Link Camber Kit
Energy Suspension Hyper-flex Full Urethane Bushings Kit
Rice/Misc:
Blue/Red/Purple Underglow
Blue/Red/Purple LEDS in heater vets
Red LED's in foot wheels
9005 Headlight conversion
Wire Tuck
Shaved door handles with electronic sensor (touch activated)
Tinted windows
EDM Rear spoiler (Flat Black)
The car would be painted a Metalic teal/blue color
Modified by dohdoh420 at 10:32 AM 11/2/2005
Modified by dohdoh420 at 10:34 AM 11/2/2005
1990 CRX DX
Engine:
Ported head
AEM cam gear
Eagle H beam rods
Polished crank
New OEM bearings
ACT Stage 3 clutch
11 pound flywheel
SI tranny
RC 550cc Injectors
Vortex FMU
Greddy type RS BOV
Tial 35mm wastegate
Short Shifter
Wheel hop bar
Electronics:
OBD1
P28 ECU
Apexi VAFC
Greddy Turbo Timer
Autopage Alarm
Interior:
Tenzo R racing seat
Si passenger seat
4pt harnesses
Kenwood deck
Kenwood amp
12" Sub
New headliner
Greddy shift ****
Aluminum pedals
Suspension/Wheels:
16" ADR rims
Rice/Misc:
Wire Tuck
Tinted windows
Kinda lost at what you are getting at.
Like redo the entire car and then turn around and sell it will all that stuff done to it?
Or sell the car as is with the parts?
Or sell the parts individually?
-Shane
-Shane
as a rule of thumb, you will never get back what you put in...unless is purely labor. But if you adding performance parts and engine swaps, kiss the money goodbye
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">Kinda lost at what you are getting at.
-Shane</TD></TR></TABLE>
Yeah, if I was to rebuild my car with all of that done to it, how much could I sell it for if/when I dont want it any more.
probly but theres no way in hell you would get that much for it.. and for the misc. parts at the end.. no one would one that stuff either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJDM »</TD></TR><TR><TD CLASS="quote">probly but theres no way in hell you would get that much for it.. </TD></TR></TABLE>
so you loose half of whats put into it.. well screw this, I'll sell mine and go buy one with most of that stuff done to it then...
man you should be happy that the 8000$ worth car would bring you 4200$....usually its around 65%-70% lost in aftermarket parts...plus the fact that people shy away from it, since they think it got beaten on (why build it up for granny driving?)
gsrturboEK
Jul 16, 2009 03:39 PM
j/k
