h22 in my civic
Old Nov 2, 2005 | 04:29 AM
baam's Avatar
Default h22 in my civic
Im swapping a h22 in my 95 civici have the complete change over from hmotorsonline and hasport mounts will i need to get certain axles or will the prelude axles work in my car also will i need to get a special header to make it go on my exhaust.thanks for the help.
Old Nov 2, 2005 | 04:42 AM
1700anddroping's Avatar
Default Re: h22 in my civic (baam)
well another h series man.welcome to the h family.you use 90-93 integra
axles..this is what i have found that works best.but some do use the inners
and outters of the prelude axle.you also use the 90-93 accorde intermediate shaft
"5-speed"....i think there is also some other ways of doing it to.just do a search
i am sure you will find what you need.
harv
Old Nov 2, 2005 | 05:31 AM
Mikey3000's Avatar
Default Re: h22 in my civic (1700anddroping)
i use the 90-93 integra axles with 90-93 accord intermediate shaft as stated above and it works beautifully. not one problem yet. i also have hasport mounts.
Old Nov 2, 2005 | 08:16 AM
EK9-Stealth's Avatar
using the DA integ axles with accord intermediate would prob be your best option. OR you can use prelude intermediate with prelude inner hubs with DA on the driver side and ZC integ on passenger. OR buy aftermarket ones..
Old Nov 16, 2005 | 12:07 PM
Gillard82's Avatar
Default Re: (EK9-Stealth)
for the axels you can make them yourslef or you can get hasports for like $500 or something. or go to autozone and get 2 sets of axels. The way u make the axels is by using 90 -91 integra axels, and remove the iner cv joint. Replave the iner cv acording to the intermediate shaft that you are using. on my set up i have a 91 prelude intermidiate shaft so im using a 90-91 prelude inner cv joint. The cv joint pull off with the removal of the metal bands, and the axel rollers are lined up and inserted in the iner cv joint channels. Put a new metal band on or put the old one on if u didnt damage it. For the Header issue, use a prelude header and have a welding shop rotate the flange so it will fit accordingly to the civic exhaust.
hatchlude
Old Nov 16, 2005 | 07:46 PM
Gillard82's Avatar
Default Re: (Gillard82)
also not to mention the rest of the modification you need to do, search and read up on this topic before atempting
chaudanova
Oct 30, 2010 05:44 PM
cycopath
Sep 7, 2008 06:23 PM
mikegeezy
Apr 9, 2006 01:14 PM
H22A1CivicEG
Jan 18, 2006 03:57 PM
SCsol
Jun 29, 2002 06:15 AM
