changing speedometer CX to Si
i just picked up 95 ex/si cluster and the mileage is lower than my CX. if i were to swap the cx speedo over to the si.. would it mess up anything? it's just 3 screws and looks easy enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice »</TD></TR><TR><TD CLASS="quote">i just picked up 95 ex/si cluster and the mileage is lower than my CX. if i were to swap the cx speedo over to the si.. would it mess up anything? it's just 3 screws and looks easy enough.</TD></TR></TABLE>
i did the same thing on my cx. it's easy don't bother trying to match the miles all you need to do is seperate the clusters by un cliping the 5 clips (3 on top, 2 on bottom) and unscrew the three screws for the speedo and it will just fall off and put your original in the new cluster and reverse the everything and your done. trust me it is really easy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">Take old one out, plug new one in. Nothing else to be done. No wiring, no mods.</TD></TR></TABLE>
Correct. However, I think he is wanting to match the miles though..
thanks guys. i just swaped the speedo from my cx cluster over the the si. works great! so basically, i got a cluster with a tach and retained my OG miles.
xXx Justin xXx
Feb 1, 2003 05:26 PM
