98 DX drivers window runner track...
Old Nov 1, 2005 | 07:17 PM
mztykal's Avatar
Default 98 DX drivers window runner track...
I think this is whats making my window fall off all the time. It just started doing it, it slides out from the runner and then falls off.
I have no power windows.
What's the part number from Honda for a new track and anyone know how to install it? Thanks!
Old Nov 1, 2005 | 07:23 PM
mztykal's Avatar
Default Re: 98 DX drivers window runner track... (mztykal)
Could it be the window regulator also? Thanks!
Old Nov 1, 2005 | 07:29 PM
djden253's Avatar
it could be the regulator i have the same problem with the driver side its not power window either my other side was doing it for a little bit to but i fixed that and got the side power window make sure that the regulator is fastened down tight and that it does not move around another thing to check to make sure that the bolt from the door that goes into the regulator are not stripped where they just keep spinning when you turn it if none of that works it has to be the regulator. oh and another thing is you know where the bottom of your window is screwed into that bracket on the regulator make sure thats not bent that could be another prbolem. but i would just get another regulator so you wont have to deal with this problem again
Old Nov 1, 2005 | 07:32 PM
mztykal's Avatar
Default Re: 98 DX drivers window runner track... (djden253)
Yah I'm gonna get a new regulator and then a new front runner track as it's bent now from the window going out of place.
Hopefully it's not too expensive and hard to do.
98civ98
Feb 4, 2014 02:40 PM
rjb8806
Mar 17, 2013 08:06 AM
bleedblue94
Nov 7, 2006 02:48 PM
Hondacrx628
Nov 13, 2004 01:23 PM
EX-T
Nov 27, 2003 07:26 AM
