SHIFT PROBLEMS HELP!
Old Mar 8, 2002 | 01:02 PM
si91's Avatar
Default SHIFT PROBLEMS HELP!
well i got this short shifter.. for my car had it in for a while i noticed 2nd when i get on to it hard and shift at 8 it grinds that gear hard it does 3rd once and a while and 4th maybe should that be me? or should it be the short shifer... my friend had the same problem.. in his 2000 dx his 2nd went completey out i think it is those GHETTO pepboys short shifter!
Old Mar 8, 2002 | 01:56 PM
Trinity's Avatar
Default Re: SHIFT PROBLEMS HELP! (JDMb16a)
that is what you get for buying a ghetto pep boys shifter. i mean come one. what i can only think it is , is a synchro but who installed the shifter
Old Mar 8, 2002 | 02:18 PM
si91's Avatar
Default Re: SHIFT PROBLEMS HELP! (Trinity)
well i guess tha is what i get then BUDDY! thanks for no ANSWER!
Old Mar 8, 2002 | 06:27 PM
E-AT_me's Avatar
short shifters suck.
btw, it did that on my car.
[Modified by Rexman, 3:27 AM 3/9/2002]
Old Mar 8, 2002 | 06:54 PM
HyperREV's Avatar
New User
Default Re: SHIFT PROBLEMS HELP! (Rexman)
the reason for the grinds is most likely the short shifter. the synchro's may already be on the way out, and the short shifter is most likely just further worsening (is that even a word?) the problem. the synchro's cant keep up with the shortened throws from the new shifter, hence the grinding.
i'd ditch it ASAP
Quik89Si's Avatar
I have a 99Dx coupe as well as my CRX...funny thing is that for being 10 years older, the CRX shifts better than the DX. It crunches sometimes into 2nd and occasionally in 4th...I don't even shift it or drive it hard, and it has just under 40K on the clock. I just don't think they make them like they used to.
Alex
Old Mar 8, 2002 | 07:05 PM
Iceycrx's Avatar
Default Re: SHIFT PROBLEMS HELP! (Quik89Si)
well honestly how much are you actually getting from the short shifter? All i hear is problems, mostly because ppl add mods onto old and used parts and expect the older parts to work like new. Id say invest into something else until u know everything else can stand the new items.
Old Mar 8, 2002 | 08:21 PM
keithv's Avatar
Default Re: SHIFT PROBLEMS HELP! (Iceycrx)
i have a dc sports short shifter and it gets a big . it grinds 2nd and 3rd lots. i actually have to shift slower so it won't grind!
this is on my teg, though. i am ditching that thing asap.
in my civic we have the stock shifter and that thing is so smooth, non-grinding. i love it and its a 13 year old car!
Old Mar 9, 2002 | 12:49 AM
chhuong's Avatar
First of all a short shifter doesn't ruin your tranny's synchros, it's the driver that ruins it. It just means your shifting faster then you are disengaging the clutch.
Old Mar 9, 2002 | 04:38 AM
Trinity's Avatar
well "BUDDY" i listed a possability and asked a question and you didn't answer mine either
Old Mar 9, 2002 | 05:33 AM
si91's Avatar
trinity sorry dude i was just in bad mood yesterday...
Old Mar 9, 2002 | 07:48 AM
90civichbsi's Avatar
anyone know why may car wouldnt go into reverse sometimes?
Old Mar 9, 2002 | 10:19 AM
Smoothy's Avatar
Default Re: SHIFT PROBLEMS HELP! (HyperREV)
Can't keep up?????? What the hell are you talking about?
Shorten travel is on the cabin side. The tranny should get the same amount of travel for each shift.
As for the grinding, maybe you're shifting too fast or too slow (not fast or as slow as your left foot).
Old Mar 9, 2002 | 10:34 AM
vsual's Avatar
lolz.....just a little correction JDMb16a..... trinity is a young lady. from GA.
base on the short shifter from pepboys...i dont see anything wrong with mines when i do hard driving from 1st to 2nd....2nd to 3rd....3rd to 4th for a year.
you might of tighten the bolt to tight to where you grind when shifting.. try loosening the bolt.
Old Mar 9, 2002 | 11:04 AM
si91's Avatar
Default Re: SHIFT PROBLEMS HELP! (vsual)
o danmn sorry girl i was in a bad mood! ;-)
Old Mar 9, 2002 | 01:58 PM
CimorelliCRX's Avatar
I bought the cheap Autozone Spectre Short shifter about 2 weeks ago, it works great, huge difference, till last week when my tranny started leaking and now it grinds and I need a new tranny, lol. I think all I need is a seal, but it gives me a reason to buy an SI tranny. So I am going to buy one this week, Monday actually, its great. I dont know if I should use the Short shifter on my SI though, I love it and all but....
Old Mar 9, 2002 | 05:12 PM
crxzc's Avatar
Actually a good short shifter (not a pep boys APC special) doesn't make any gear grind. i have a OBX short shifter w/neuspeed bearings and it works great. the reason certain gears grind is because of the driver or the syncros are shot. get a tranny re-build kit for like 150 bucks and your tranny will run like new.
Old Mar 9, 2002 | 07:23 PM
CRXtc 90's Avatar
i sometimes have a few grinds with my short shifter but a friend told me neuspeed sells a bushing that is supposed to help grinding.
Old Mar 10, 2002 | 11:36 AM
keithv's Avatar
Default Re: SHIFT PROBLEMS HELP! (90civichbsi)
my teg does this alot. usually what i do is i let the clutch back out (with the car in neutral), then re-engage the clutch and try selecting reverse. it usually works the second time.
also, i think this occurs on most cars and isn't really a problem...
Old Mar 10, 2002 | 01:10 PM
Urban Business
Guest
Posts: n/a
Default Re: SHIFT PROBLEMS HELP! (breaka_1_9)
reason for reverse not going in is becasue there is no syncro in reverse. fararris and lambo's have them most cars dont. try reving your motor to match speeds while shitfing in reverse. also the double clutch will work as well
Old Mar 10, 2002 | 03:36 PM
crxzc's Avatar
Default Re: SHIFT PROBLEMS HELP! (TorteX)
another easy thing to do when going into reverse is to put it into 2nd then reverse. it will not grind at all. double clutch it or shift into a different gear (4th) , then shift into 3rd and it shouldn't grind.
TheCiv127
Transmission & Drivetrain
Jul 17, 2012 10:45 AM
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
95turbodteg
Honda Civic (2006 - 2015)
Jan 14, 2007 07:56 PM
laosbboy
Jul 1, 2003 12:21 AM
threatcon13
Aug 7, 2001 04:20 PM
