motor trouble. some one help me
well i just put a jdm gsr motor in my car, it starts up fine and all that good stuff. The problem i am having is that when i took it out for a spin and press on the gas it accelerates but to a certian ponit, like 10 mph and boggs down and wont go any faster and when i try to shift it is like the shifter is stuck and wont come out. this happens in all the gears. i am stuck and dont know what to check or do. soo can any one help me ?
i dont really think it is the tranny, when i press on the gas it will start to pick up then boggs down like it is struggling to run and i dont know waht the problem is
1 check all engine grounds
2. check all fluid levels
3. Are there any CEL?
4. is your tranny fluid topped off?
5. Shift linkage on correctly and secure?
Could be a bent Shift Fork in the transmission as well
everything u listed i did and there is a cel on it and i am trying to firgure it out but i cant find the stupid jumper and do u thiunk it is like that due to the fact that i have not wired up the vtec and knock sensors yet
i was wrong it is not fixed. when i went to take her out for another quick spin it started to bog once again. so any thought of what could be wrong would help. thanks.
Modified by Eg6_rAcEr at 11:54 PM 11/2/2005
I was gonna say u really wont be able to shift if u dont have both the B Series bars for the linkage, then the shifter will sit forward a lot... and will be a pain in the *** to shift... tat happend in my z6 when I didnt have both bars for the z6 linkage and my b16 when I swapped that..... hope you figure everything out...
JunIntegra
May 17, 2003 02:55 PM
