b18c1 into 97 4dr civic
im trying to put a b18c1 obd1 into my 4dr i have the complete swap with avid motor mountsdo i use the gsr rear tranny bracket or i have to used the si bracket? which wiring harness should i use my car is an ex but it was auto but i did the 5spd convertionand i think if i use my stock wiring im gonna have problems cuase is different the auto and th manual harness. should i make the motor obd2 or wire my car obd1. any replies will help thanx
i dont understand why you would want to do that, i would think it would be alot more work than its worth just wire it obd1 and get the obd2 to obd1 conversion harness for the ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic18 »</TD></TR><TR><TD CLASS="quote">do i use the gsr rear tranny bracket or i have to used the si bracket? </TD></TR></TABLE>
i believe si
i believe si
NOman0608
Jul 26, 2007 10:28 AM
