trouble ideling (timing maybe?)
Old Nov 1, 2005 | 06:00 PM
NoahSukata's Avatar
Default trouble ideling (timing maybe?)
sup guys well i got the car runnin after the headgasket change.. but now it wont idle unless i push the distributor all the way toward the car... and it still does idle high enough...the cam gears and crank are all set at TDC... could it be that my valve lash isnt in spec? i need to get them adjusted.. i hear them clickin...
Old Nov 2, 2005 | 05:18 AM
djtony5's Avatar
Default Re: trouble ideling (Da-teg)
Did you change back your timing with a timing gun? If not, then that probaly be the cause of the idling problem.
Old Nov 2, 2005 | 01:28 PM
NoahSukata's Avatar
na i didnt.. what exactly do u do to do it w/ a gun? whats the jumper? ect...
Old Nov 2, 2005 | 04:10 PM
zman's Avatar
Default Re: (Da-teg)
well the jumper is to jump the diagnostic plug, u know where you jump to get the CEL codes.
You hook the gun up to the battery and #1 spark plug wire. The light flashes when #1 spark plug fires.
Here's a good link with a how-to on ignition timing.
http://www.c-speedracing.com/h...g.php
mwwtx
Feb 10, 2010 04:26 PM
sde780
Jul 30, 2009 07:38 AM
type Gendy
May 14, 2008 12:29 PM
matbh22a
Jun 19, 2007 12:15 PM
Jmumblez2001
Nov 3, 2006 01:36 AM
