Anti freeze mixture..
Old Nov 1, 2005 | 05:49 PM
vltnolia's Avatar
Default Anti freeze mixture..
I have a 1999 civic hx and I just flushed the radiator with water for about 5 mins. It didnt drain completly cuz I didnt have the time. I noticed a slight green coolant coming out but I plugged it up anyways. Then I added some orange coolant to it.
My question is will there be any harm coming from mixing orange coolant and green coolant. Note there wasnt alot of green coolant.
Old Nov 1, 2005 | 05:53 PM
ThefirstPACT's Avatar
Default Re: Anti freeze mixture.. (vltnolia)
That orange **** is for GM! Take that **** out there and NEVER touch your car again!
Old Nov 1, 2005 | 05:56 PM
si0385.'s Avatar
Default Re: Anti freeze mixture.. (ThefirstPACT)
yes harm can come from mixing them
u need a special radiator for the extended life antifreeze or it will corrode
drain it asap and refill it with green antifreeze
Old Nov 1, 2005 | 05:57 PM
vltnolia's Avatar
Your telling me you cant use that on hondas?
si0385.'s Avatar
Default Re: (vltnolia)
yes
Old Nov 1, 2005 | 06:02 PM
vltnolia's Avatar
I was unaware. I will drain it out rite now.
xdrian's Avatar
Default Re: (turbodreamz0385)
y not? its antifreeze?
Old Nov 1, 2005 | 06:05 PM
si0385.'s Avatar
Default Re: (xdrian)
i was told by one of the techs at a local Chevy dealership that there is a chemical in it that will corrode the metal in radiators
the new gm radiators that have the extended life antifreeze are made from something different
im not sure about the exact chemistry but now that this was brought up i am gona look into it cuz im curious myself
EG2Driver's Avatar
ratio is 50-50 for hondas. Use distilled water and YELLOW coolant.....the ratio stays the same regardless of how the temperate is (cold or warm) Check your hoses and radiator for deposits. I did mine last weekend, easy as pie just do it right and make sure to bleed ur radiator, otherwise ur CEL light will turn on. Luck to you, bro
Old Nov 1, 2005 | 06:06 PM
Why dont you **** in it's liquid...right?! It not for HONDAS! Just put the green stuff in and it wil be fine!
si0385.'s Avatar
Default Re: (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">ratio is 50-50 for hondas. Use distilled water and YELLOW coolant.....the ratio stays the same regardless of how the temperate is (cold or warm) Check your hoses and radiator for deposits. I did mine last weekend, easy as pie just do it right and make sure to bleed ur radiator, otherwise ur CEL light will turn on. Luck to you, bro</TD></TR></TABLE>
only one prob... yellow anitfreeze is expensive as hell
just use green it even comes in premix and its less than 1/2 the price
Old Nov 1, 2005 | 07:54 PM
vltnolia's Avatar
No biggie, It was just a mistake. I just had the orange in for a day, now its out. I have green in it now.
Old Nov 1, 2005 | 08:03 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vltnolia &raquo;</TD></TR><TR><TD CLASS="quote">No biggie, It was just a mistake. I just had the orange in for a day, now its out. I have green in it now.</TD></TR></TABLE>
If you drove your car than it is in the block and you still have orange coolant in your car. So if you did drive it you're going to need to get/do a complete coolant flush. I suggest you take it somewhere and have them do it.
Old Nov 1, 2005 | 08:10 PM
.Ry's Avatar
.Ry
Default Re: (SOHC4life 96)
Let the engine cool down and drain the radiator. Turn the climate level to hot, so you can flush out the heater hoses. Take off the upper and lower radiator hoses, and then take out the thermostat and replace the housing. Reattach the lower hose to the thermostat housing. Take a garden house and place it into the upper part of the block and let it run for awhile. I had the engine cool so you dont worry about cracking a hot block with cold water. Since you left the lower hose unattached to the radiator the water will run right to the ground instead of all over the engine bay. Once its all cleaned out get out as much water as you can. Put the thermostat back in, replace all the hoses. Top off the radiator with GREEN 50/50 water/antifreeze. Let the car warm up and top off as needed.
Old Nov 1, 2005 | 08:16 PM
ROK801's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">Let the engine cool down and drain the radiator. Turn the climate level to hot, so you can flush out the heater hoses. Take off the upper and lower radiator hoses, and then take out the thermostat and replace the housing. Reattach the lower hose to the thermostat housing. Take a garden house and place it into the upper part of the block and let it run for awhile. I had the engine cool so you dont worry about cracking a hot block with cold water. Since you left the lower hose unattached to the radiator the water will run right to the ground instead of all over the engine bay. Once its all cleaned out get out as much water as you can. Put the thermostat back in, replace all the hoses. Top off the radiator with GREEN 50/50 water/antifreeze. Let the car warm up and top off as needed.</TD></TR></TABLE>
dex cool will eat the expletive out of hoses...
do this, then take your car to a real mechanic from now on.
raju687
Sep 16, 2011 05:42 PM
ricerollz
Sep 22, 2010 10:05 AM
nickgomez
Feb 4, 2004 09:27 AM
LillDragun
Oct 25, 2002 04:25 PM
