Third (same) caliper this year....
Old Nov 1, 2005 | 12:55 PM
staticCRX's Avatar
Default Third (same) caliper this year....
So, this is the third rear driver side caliper I have gone through in the past year.
1) when I bought the car
2) the one I replaced the OEM with locked
3) the replacement for the second caliper is now locked
both times I replaced the calipers I replaced them with a "loaded caliper" set from the local autozone.
when I say "locked" I mean "piston won't retract" so the pad just rubs all the way down until it doas nothing. WHAT WOULD CAUSE THIS?!? I have Earls SS brake lines that are only 4 months old on there. Two of the three calipers were SS lines and the first was OEM lines.
::shrugs:: I just don't wanna go through warranty crap or the time to replace it again. I asked a local mechanic and he gave me the usual "we'd have to look at it" crap.
Old Nov 1, 2005 | 01:00 PM
CRX Toad's Avatar
Default Re: Third (same) caliper this year.... (staticCRX)
Okay and how old is the MC...sounds like you got something in the lines some kind of crap or you live in the salty sea.
Old Nov 1, 2005 | 01:09 PM
PURPLETERROR aka BIGMATT's Avatar
master cyl or somethig stuck in the line or prop valve
Old Nov 1, 2005 | 01:29 PM
CRX Toad's Avatar
Once it locks have you tried to bleed that caliper and see if it will release? I had a motorcycle caliper that would lock due to bad MC. I could bleed it and then it would release I would attempt that before you do another caliper. Just something to think about.
Old Nov 1, 2005 | 02:18 PM
staticCRX's Avatar
Hmm...not sure how old the MC is or the prop valve...thought about putting the '91 EX MC in.
I don't believe bleeding it would do anything; I've tried taking it off and trying the "c clamp" technique only for it to tick me off more Thanks for the suggestion tho.
Modified by staticCRX at 7:19 PM 11/1/2005
Modified by staticCRX at 7:20 PM 11/1/2005
Old Nov 1, 2005 | 03:30 PM
AZTEKEF9's Avatar
Default Re: (staticCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticCRX &raquo;</TD></TR><TR><TD CLASS="quote">Hmm...not sure how old the MC is or the prop valve...thought about putting the '91 EX MC in.
Modified by staticCRX at 7:20 PM 11/1/2005</TD></TR></TABLE>
on the rears u dont need a c clamp.....the piston actualy acts like a big screw...when u press the brakes it turns and it tightrnd instead of compressing...i learned the hard way....now i have to replace it..
Old Nov 1, 2005 | 06:57 PM
staticCRX's Avatar
Default Re: (AZTEKEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">
on the rears u dont need a c clamp.....the piston actualy acts like a big screw...when u press the brakes it turns and it tightrnd instead of compressing...i learned the hard way....now i have to replace it.. </TD></TR></TABLE>
I don't know why...but that just totally foncused me?¿ So what you are trying to say is that you can't push it in but you can twist it back in?
Pandahatch
Jul 2, 2023 09:06 PM
fuel..
Aug 21, 2012 07:46 PM
Damanzi
Suspension & Brakes
Jan 18, 2012 07:53 PM
Nisif
20
Sep 26, 2007 07:04 AM
ImPuLsIvE
May 7, 2007 12:44 PM
