passing smog/BAR with Greddy turbo
Old Nov 1, 2005 | 09:32 AM
Wazup's Avatar
Default passing smog/BAR with Greddy turbo
not sure if this should be in forced induction..
anyway, anyone pass CA emmissions or smog ref with a greddy turbo?
Old Nov 1, 2005 | 09:35 AM
Fatchance187's Avatar
Default Re: passing smog/BAR with Greddy turbo (Wazup)
I don't think it'll effect it.. I think they only smog test at idle so I think you'll be alright. not sure though good luck
Old Nov 1, 2005 | 09:40 AM
Wazup's Avatar
Default Re: passing smog/BAR with Greddy turbo (Fatchance187)
i think the main problem will be the visual inspection
Old Nov 1, 2005 | 09:41 AM
Marauder's Avatar
If its OBD2, they scan the ECU and its tested at 15mph and 25 mph
You must have your EO sticker on the car.
Old Nov 1, 2005 | 09:42 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it'll effect it.. I think they only smog test at idle so I think you'll be alright. not sure though good luck</TD></TR></TABLE>
Wrong. I guess you don't live in Cali. So then that makes me wonder... why the hell are you wasting your time responding if you have no clue?
Old Nov 1, 2005 | 09:59 AM
Wazup's Avatar
Default Re: passing smog/BAR with Greddy turbo (Hybrid93Eg)
all good though, maybe he read the post wrong
anyway, would using the greddy emanage help with a OBD 2 car?
Old Nov 1, 2005 | 10:18 AM
Luserkid's Avatar
why are you going to a smog ref? Just go to a normal smog station unless you swapped the motor. And have that sticker.
If you do need to go to the ref, make sure your not throwing any codes, your running stock ECU with the shitty Greddy piggy back and have your sticker. Should pass no problem.
LAOS
Sep 4, 2005 10:28 AM
ThaCivicAssassin
Mar 22, 2005 03:21 PM
SPOONup
Jan 7, 2005 01:25 PM
Cyrio
Oct 6, 2004 01:34 PM
is3oo
Aug 27, 2004 12:36 AM
