Honda Accord 3.0 liter '98 Catalytic Converters
Old Nov 1, 2005 | 09:20 AM
marshalltech's Avatar
Default Honda Accord 3.0 liter '98 Catalytic Converters
I have a confirmed bad (below threshold) Catalytic Converter an need a replacement.
However, I am having a difficult time finding a good replacement for the 3.0 liter engine. The only place I was able to find one for the 3.0 liter engine was at: http://www.convertersexpress.c...unt=6 at $138.
There are no emissions laws here in FL so I wouldn't minds geting a "high-flow" cat.
Who here is web savy enough to find me a good deal on a '98 Accord 3.0ltr Catalytic Converter. I would owe you my gratitude.
Old Nov 1, 2005 | 09:23 AM
deserthonda's Avatar
Default Re: Honda Accord 3.0 liter '98 Catalytic Converters (marshalltech)
how many miles do u have on car????????????? honda extended their warranty on this . i believe up to 75-80k miles....give ur local dealer a call
Old Nov 1, 2005 | 09:25 AM
Default Re: Honda Accord 3.0 liter '98 Catalytic Converters (deserthonda)
Thanks for quick reply, you rock.
I have over 128,000 miles. The car is 7 years old. So I am out of warranty here.
My guess is the SRI intake led to the premature failure.
I noticed the problem when my idle would fluctuate from 1000 to 2300 rpm every second.
Old Nov 1, 2005 | 11:39 AM
iam7head's Avatar
it's probably not your intake, it's not even yor cat is bad.
i am putting my bet on the o2 sensor.
the cat rarely goes bad unless you are running leaded aircraft gas
what leads you to believe that your cat is failing?
putting a crappy hi flow cat will give you a CEL which will hurt your mileage per gallon. if you in cali, you'll get a fat ticket and it will not pass smog check for it
Old Nov 1, 2005 | 01:02 PM
Default Re: Honda Accord 3.0 liter '98 Catalytic Converters (iam7head)
I had a diagnostic ran and the code was for (Catalytic Converters below threshold).
It could be a bad O2 sensor. I am going to Voltimeter and try to test it first before I go buy anything...
Old Nov 1, 2005 | 04:12 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote"> honda extended their warranty on this . i believe up to 75-80k miles.... </TD></TR></TABLE>
There's no extension on those. They had an 80,000 mile federally mandated warranty from th git-go.
CMC2012
Dec 9, 2011 03:21 PM
tr0n9h
Jul 18, 2011 11:14 AM
rockermikey
Aug 31, 2008 07:28 PM
swaps_1979
Dec 14, 2005 12:01 PM
teg96
Nov 6, 2003 05:17 AM
