painting wheel... question
Old Nov 1, 2005 | 08:54 AM
Nothing.Special's Avatar
Default painting wheel... question
so i sanded down my wheel and cleaned it up and after applying the primer, it came out looking all sandy and i could actually wipe off the sandy feeling with my fingers.
Why did it come out like that? Is it the primer im using? The technique i used to put it on? Too much?
any help is much appreciated, thanks guys
Old Nov 1, 2005 | 09:18 AM
FLiPFeLLaH's Avatar
Default Re: painting wheel... question (Nothing.Special)
ummm put a shitload of clearcoat hahaha.. and i'll post a pic so thers a pic on here
Old Nov 1, 2005 | 09:23 AM
AVA's Avatar
AVA
Sláinte
Default Re: painting wheel... question (FLiPFeLLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLiPFeLLaH &raquo;</TD></TR><TR><TD CLASS="quote">ummm put a shitload of clearcoat hahaha.. and i'll post a pic so thers a pic on here
How does that have anything to do with the origional post?
Are you sure the primer is rubbing off? Primer is supposed to be rough
Old Nov 1, 2005 | 09:26 AM
WishinItWas's Avatar
you probable got sandable primer by accedent it goes on really thick but when you touch it it comes right off. go get some real primer thats not sandable
Old Nov 1, 2005 | 09:28 AM
FLiPFeLLaH's Avatar
Default Re: painting wheel... question (^Jae)
GO TO MAZDA FORUM hahahahaha i kid i kid.. and to the other guy umm nothing really.. o the subaru had same problem...??
Old Nov 1, 2005 | 09:42 AM
thanks guys, any more ideas?
Old Nov 1, 2005 | 09:47 AM
I Have an STD's Avatar
wrenchin'
make sure the paint cans are warm when u spray them. leave paint flows and stick better when it is warm. make sure the wheel is warm, anout 50-80 degrees and leave the can of paint in a big huge bucket of 85-95 degree water. paint will come out SMMMOOOOTH
BRETT
Old Nov 1, 2005 | 09:50 AM
Spoogen_1's Avatar
Default Re: painting wheel... question (I Have an STD)
Old Nov 1, 2005 | 09:59 AM
NickW's Avatar
Default Re: painting wheel... question (Nexus131)
Is the primer coming off or just have dust that you can wipe/blow off? If the primer is sticking, but there is dust thats FINE. However, you'll want to let the dust settle and then rinse/wipe and clean the surface to get the dust off. Wipe all the access dust off, and wash the surface. Help to get all the dust/debris off the surface.
If the primer is coming off al together, then rough the surface of the wheel up more and make sure you are spraying in some extreme conditions.
Old Nov 1, 2005 | 10:16 AM
al3e's Avatar
Default Re: painting wheel... question (NickW)
when you paint, before you paint, clean clean clean clean clean and i forgot to add... clean. with either a pepr towel, or lintless fabric!
Old Nov 1, 2005 | 12:29 PM
thanks
this time around i plan on trying a different primer and cleaning the wheel INSANELY heh
any other input?
Old Nov 1, 2005 | 02:38 PM
95greenteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nothing.Special &raquo;</TD></TR><TR><TD CLASS="quote">thanks
any other input?</TD></TR></TABLE>
Same thing happened to me with my primer...I just sanded it down very lightly with a fine grit and it came out smooth like butta...
Aushonda
Jul 27, 2008 12:47 AM
civicDX2178
Jul 2, 2006 09:01 AM
daonei
May 23, 2004 01:16 PM
holeymoly
Mar 5, 2004 01:29 AM
