wont go into gear????
Old Nov 1, 2005 | 06:11 AM
TurboSI24's Avatar
Default wont go into gear????
Well i just bought an 92 eg and the guy said he adjusted the clutch cause his daughter was having trouble pressing the peddle, so when i was driving it felt fine no grinds when shifting, and he said he changed the clutch, but this morning i couldnt get it into gear so what could be the problem, is it the slave cylinder????
Old Nov 1, 2005 | 07:22 AM
nocturnaldragon's Avatar
Default Re: wont go into gear???? (TurboSI24)
Can you shift it while the car is off?
If you can then it has something to do with the clutch, check the master for leasks the most common spot for it to leak is by the pedal in the car. Also check the slave by the rubber boot on the trans. Have a buddy check to make sure your getting movement when you press in the clutch.
If thats all good then someelse is wrong with the clutch or pressure plate if you can shift with the car off.
If you cant shift when the car is off then its the trans.
dohctor_B
Transmission & Drivetrain
Sep 4, 2012 06:31 AM
jwshilli
Jul 14, 2009 03:02 PM
mattmw88
Dec 9, 2006 06:00 AM
4thgenlude
Oct 5, 2004 09:30 PM
SteelCityKid
Jun 14, 2002 10:12 AM
