30/40 and 40/40 Proportioning valve question.
i did my search and i was wondering if it's ok for me to use the 40/40 pv on my eh2 if i have the 9.5 front brakes and integra rear disc in the back? or should i use the 30/40 since it's for 9.5 front brakes. eventually i will change the front to integra brakes also but i didn't find a set yet. so will it be ok if i use the 40/40 with the stock front brakes i have now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phantastic »</TD></TR><TR><TD CLASS="quote">i did my search and i was wondering if it's ok for me to use the 40/40 pv on my eh2 if i have the 9.5 front brakes and integra rear disc in the back? or should i use the 30/40 since it's for 9.5 front brakes. eventually i will change the front to integra brakes also but i didn't find a set yet. so will it be ok if i use the 40/40 with the stock front brakes i have now? </TD></TR></TABLE>
you'll be fine, in fact you can reuse the 30/40 PP if you have it. I have the 10.2 front rotors and I'm using the 30/40 PP. I couldn't tell any differences between the 30/40 and 40/40 PP.
matthevelli
11
May 31, 2008 05:43 AM
