question about shifting into fifth gear?
Old Oct 31, 2005 | 06:03 PM
ablack934doorcivic's Avatar
Default question about shifting into fifth gear?
some times when i try to shift into fifth gear it woun't go into gear this is a b16sirII tranny. now the problem is sometimes when i try to down shift i have a hard time getting it out of fifth gear like there is tension holding it back. here is where it gets tricky. if i push the clutch in move out of forth let off the clutch push the clutch back in then it will shift right into 5th gear otherwise when i just hold the clutch down when shifting from forth it won't go is this a bad clutch or worn syncros. what could it be?
Old Oct 31, 2005 | 06:56 PM
JDMy0's Avatar
141.217.174.219
i have the same problem, sometimes it wont go into first when im at a light so i play around with the clutch until it does
Old Oct 31, 2005 | 07:48 PM
HiProfile's Avatar
Default Re: question about shifting into fifth gear? (ablack934doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">if i push the clutch in move out of forth let off the clutch push the clutch back in then it will shift right into 5th gear</TD></TR></TABLE>
You just described double-clutching. The synchro (in good cindition) eliminates the need to do that. The synchro nearly matches the two gears about to enguage so that they slip together w/little effort. Double-clutching does the same thing, mainly allowing the shafts to slow down somewhat (synchronize naturally).
Long story short, the main cause is skipping gears and going right to 5th. The synchro is made to match the gear below it, not 2-3 gears below it. To 'skip' I usually push in the clutch and continue the pattern to 5th (touch each gear between). When my LS tranny was taken apart, 5th was profusely worn, yet I never power-shifted into 5th, always slow and gentle. My guess was the precious owner.
Old Oct 31, 2005 | 08:13 PM
E.Honda's Avatar
Default Re: question about shifting into fifth gear? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote"> My guess was the precious owner.</TD></TR></TABLE>
Why was he so precious?
Old Oct 31, 2005 | 08:17 PM
vc's Avatar
vc
Default Re: question about shifting into fifth gear? (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">Why was he so precious?</TD></TR></TABLE>
because he screw'd up the synchro
Old Oct 31, 2005 | 08:35 PM
hushypushy's Avatar
he was so precious because the C key is next to the V key on the keyboard, thus turning previous into precious
Old Nov 1, 2005 | 02:02 PM
Default Re: (hushypushy)
thanks for the insight on this problem i'm just trying to find the best way to fix it
jli18
Nov 5, 2006 09:12 PM
Chief Brody
Aug 4, 2004 09:28 PM
canadaitr
Mar 24, 2003 07:17 PM
crxaddikt
16
Apr 4, 2002 05:25 AM
FlipboiGSR
Sep 12, 2001 09:07 PM
