5th gen: LX and EX compatibility
Old Oct 31, 2005 | 05:13 PM
tonezilla's Avatar
Default 5th gen: LX and EX compatibility
i need to buy the intermediate pipe for my 94 accord . i am purchasing it from this site http://www.secureleadercom.com...block . however, they offer two of them . one for a LX (part #524019) and a EX (part #524021 ) . is there any difference between the two such as fitment, size, etc ? i always thought that the LX and EX were the same except for the muffler tips .
Old Oct 31, 2005 | 05:15 PM
zidek's Avatar
since i have the oem EX muffler with the pipe that connects to the intermidiate one, i'd assume it with fit perfect
Old Oct 31, 2005 | 05:18 PM
momstaxi's Avatar
Default Re: 5th gen: LX and EX compatibility (tonezilla)
yes, they are the same, it will fit fine..
Old Oct 31, 2005 | 05:39 PM
gianinline's Avatar
The difference between the LX and EX, is that the muffler has a 2 tips at the end for EX, when LX has a single one. I also believe that the exhaust manifold for DX and LX is slightly different from the EX. Other than that, everything should be the same. But the company has to follow the idea that LX and EX are totally different.
So the answer, should be yes!
Old Oct 31, 2005 | 05:54 PM
BLKFLSH's Avatar
May have something to do with oxygen sensors. On 4th gen the ex had two and the lx had one.
Old Oct 31, 2005 | 07:07 PM
tonezilla's Avatar
Default Re: 5th gen: LX and EX compatibility (BLKFLSH)
i also noticed something different between the two . i noticed the LX has a smaller resonator/flex pipe compared to the EX . is there any reason for that ?
LX:
EX:
Old Oct 31, 2005 | 07:46 PM
hondabum's Avatar
well what one do you have lx or ex, and what one is less money? i would go with the cheaper one but thats just me why do you ask?
Old Oct 31, 2005 | 08:28 PM
tonezilla's Avatar
Default Re: 5th gen: LX and EX compatibility (hondabum4life)
i drive an lx, but i am using a ex muffler . they are both priced the same, but i just wanted to make sure if it was ok to use either one .
Old Oct 31, 2005 | 08:30 PM
momstaxi's Avatar
the difference in the resonator size is probably just because of the different exhaust manifold differences or something, but again, as far as fitament between the two trim models you can interchange whatever part you want..
Old Oct 31, 2005 | 09:13 PM
hondabum's Avatar
Default Re: 5th gen: LX and EX compatibility (momstaxi)
well a bigger resonator would make it quieter correct
Old Nov 1, 2005 | 01:25 PM
SearchBeforeUPost!'s Avatar
The downpipes are NOT interchangable between EX and LX, you can see clearly in the above picture. The EX has is 4-2-1 and the LX is 4-1. The only way you can use the EX downpipe is if you swap over the EX exhaust manifold also.
Old Nov 1, 2005 | 01:51 PM
fw190bvi's Avatar
Default Re: 5th gen: LX and EX compatibility (SearchBeforeUPost!)
intermediate pipe bolts up to the cat. and EX pipe will NOT LINE UP on a 94-95 LX. its the flange design off of the cat. however, it WILL line up on a 96-97 LX. EX midpipe will NOT line up on a DX
Old Nov 17, 2005 | 11:58 AM
tonezilla's Avatar
Default Re: 5th gen: LX and EX compatibility (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">intermediate pipe bolts up to the cat. and EX pipe will NOT LINE UP on a 94-95 LX. its the flange design off of the cat. however, it WILL line up on a 96-97 LX. EX midpipe will NOT line up on a DX</TD></TR></TABLE>
sorry for bringing back up a old thread, but what's different about the flange design between the EX and LX cat/pipe ? the flange design looks the same to me (from the two pics posted above) and i see no differences .
allm0torGSR
Honda Civic (2001 - 2005)
Jul 31, 2007 06:23 PM
FG Two
Jan 19, 2007 06:25 PM
vabchaccord
Aug 17, 2004 10:59 AM
david90
Oct 17, 2003 06:37 PM
vtec69
Apr 22, 2002 12:29 PM
